Using input() with a variable
knobby67
PostPosted: Thu Sep 28, 2006 9:41 am     Reply with quote
Hello I’m hoping someone can help me out with this, basically I have a structure define as below
struct meter_input
   byte input;
   long count;
   char status;
I then have structure like the below
STRUCT meter_input _10pCoinInput=
   PIN_B0,
   0,
   LO,
Where input is used to store the pin to be read with the library function input()
I call the function
ReadStatus(&_10pCoinInput);
The ReadStatus is as follows
void ReadStatus(struct meter_input *meter)
   if(meter->status==HIGH)         //is the status high
      if(!input(meter->input))      //has the input dropped low
         meter->status=LO;
         meter->count++;
         return;
   else………………………
However this gives a error
Expression must evaluate to a constant
As far as I’m awear it does? Input is PIN_B0, I’ve tried defining input with a const ie const byte input; but this gives an error can anyone advise?
PostPosted: Thu Sep 28, 2006 10:06 am     Reply with quote
This thread has links to the routines:
http://www.ccsinfo.com/forum/viewtopic.php?t=27923&highlight=18f+16f
