theteaman
Quick PIC question RE Hz |
Posted: Wed Sep 13, 2006 4:56 pm |
Hi
If I use a 20MHz crystal, the PIC runs at 5MHz or 5,000,000 Hz.... Also, most instructions run for one cycle, with some running for 2 or 3 cycles.
Then, say I have a loop that simply toggles an output pin on/off, and say, one iteration of the loop is approximately 10 cycles, would the output pulse of the pin equal 5MHz/10 = 500kHz?
thanks |
Douglas Kennedy
Posted: Wed Sep 13, 2006 5:56 pm |
Yes goto statements take up two cycles everything else one cycle so if 10 cycles is your total in your loop the pin will go high and low 5 mhz/10 or 500 khz. |
theteaman
Posted: Wed Sep 13, 2006 5:59 pm |
great, thanks! |
