Quick PIC question RE Hz
theteaman
PostPosted: Wed Sep 13, 2006 4:56 pm     Reply with quote
Hi
If I use a 20MHz crystal, the PIC runs at 5MHz or 5,000,000 Hz.... Also, most instructions run for one cycle, with some running for 2 or 3 cycles.
Then, say I have a loop that simply toggles an output pin on/off, and say, one iteration of the loop is approximately 10 cycles, would the output pulse of the pin equal 5MHz/10 = 500kHz?
thanks
Douglas Kennedy
PostPosted: Wed Sep 13, 2006 5:56 pm     Reply with quote
Yes goto statements take up two cycles everything else one cycle so if 10 cycles is your total in your loop the pin will go high and low 5 mhz/10 or 500 khz.
theteaman
PostPosted: Wed Sep 13, 2006 5:59 pm     Reply with quote
great, thanks!
