FOR loop not looping
Markdem
PostPosted: Mon Sep 18, 2006 5:37 am     Reply with quote
Hello all, i am tring to build a light timer that can control 4 sets of lights. The following code is what i use to work out if the light should be on or off
void lightwork()
      ds1307_get_time(hrs,min,sec);
      for (i=0; i<4; i++)
                  if ((lightbank_on_h[i] == lightbank_off_h[i]) && (lightbank_on_m[i] == lightbank_off_m[i]))
                        outputstates[i] = 1;
                     else if ((lightbank_on_h[i] == lightbank_off_h[i]) && (lightbank_on_m[i] <lightbank_off_m>= lightbank_on_m[i]) && (min <lightbank_off_m> lightbank_off_m[i]))
                           if ((hrs != lightbank_on_h[i]) || ((hrs == lightbank_on_h[i]) && ((min >= lightbank_on_m[i]) || (min < lightbank_off_m[i]))))
                              outputstates[i] = 0;
                     else if (lightbank_on_h[i] < lightbank_off_h[i])
                           if (((hrs == lightbank_on_h[i]) && (hrs <lightbank_off_h>= lightbank_on_m[i])) || ((hrs > lightbank_on_h[i]) && (hrs <lightbank_off_h> lightbank_on_h[i]) && (hrs == lightbank_off_h[i]) && (min <lightbank_off_m> lightbank_off_h[i])
                           if (((hrs == lightbank_on_h[i]) && (hrs > lightbank_off_h[i]) && (min >= lightbank_on_m[i])) || ((hrs > lightbank_on_h[i]) || (hrs < lightbank_off_h[i])) || ((hrs < lightbank_on_h[i]) && (hrs == lightbank_off_h[i]) && (min < lightbank_off_m[i])))
               if(outputstates[i] == 0)               //check to see if above code turned the lights on or off
                     switch (i)
                           case 0:
                              device_off(light1);
                           case 1:
                              device_off(light2);
                           case 2:
                              device_off(light3);
                           case 3:
                              device_off(light4);
                     switch (i)
                           case 0:
                              device_on(light1);
                           case 1:
                              device_on(light2);
                           case 2:
                              device_on(light3);
                           case 3:
                              device_on(light4);
            } //close for loop
   } //close function
Problem is that it will only work when i=0. eg the loop will now work once, and then it will exit. Can anybode see why??
Thanks, Mark
PostPosted: Mon Sep 18, 2006 6:29 am     Reply with quote
Only use 'break' inside the switch statement, in all other situations it will cause your program to break out of the current loop, i.e. out of your while loop.
rwyoung
1) How is "i" defined?
2) Where is "i" defined?
3) Carefully re-read what a "break" statement does.
Rob Young
