Markdem
FOR loop not looping |
Posted: Mon Sep 18, 2006 5:37 am |
Hello all, i am tring to build a light timer that can control 4 sets of lights. The following code is what i use to work out if the light should be on or off
void lightwork()
ds1307_get_time(hrs,min,sec);
for (i=0; i<4; i++)
if ((lightbank_on_h[i] == lightbank_off_h[i]) && (lightbank_on_m[i] == lightbank_off_m[i]))
outputstates[i] = 1;
else if ((lightbank_on_h[i] == lightbank_off_h[i]) && (lightbank_on_m[i] <lightbank_off_m>= lightbank_on_m[i]) && (min <lightbank_off_m> lightbank_off_m[i]))
if ((hrs != lightbank_on_h[i]) || ((hrs == lightbank_on_h[i]) && ((min >= lightbank_on_m[i]) || (min < lightbank_off_m[i]))))
outputstates[i] = 0;
else if (lightbank_on_h[i] < lightbank_off_h[i])
if (((hrs == lightbank_on_h[i]) && (hrs <lightbank_off_h>= lightbank_on_m[i])) || ((hrs > lightbank_on_h[i]) && (hrs <lightbank_off_h> lightbank_on_h[i]) && (hrs == lightbank_off_h[i]) && (min <lightbank_off_m> lightbank_off_h[i])
if (((hrs == lightbank_on_h[i]) && (hrs > lightbank_off_h[i]) && (min >= lightbank_on_m[i])) || ((hrs > lightbank_on_h[i]) || (hrs < lightbank_off_h[i])) || ((hrs < lightbank_on_h[i]) && (hrs == lightbank_off_h[i]) && (min < lightbank_off_m[i])))
if(outputstates[i] == 0) //check to see if above code turned the lights on or off
switch (i)
case 0:
device_off(light1);
case 1:
device_off(light2);
case 2:
device_off(light3);
case 3:
device_off(light4);
switch (i)
case 0:
device_on(light1);
case 1:
device_on(light2);
case 2:
device_on(light3);
case 3:
device_on(light4);
} //close for loop
} //close function
Problem is that it will only work when i=0. eg the loop will now work once, and then it will exit. Can anybode see why??
Thanks, Mark |
Posted: Mon Sep 18, 2006 6:29 am |
Only use 'break' inside the switch statement, in all other situations it will cause your program to break out of the current loop, i.e. out of your while loop. |
rwyoung
1) How is "i" defined?
2) Where is "i" defined?
3) Carefully re-read what a "break" statement does. _________________ Rob Young
