18(L)F45J10: ADC not work !!!
messerschmitt
PostPosted: Tue Aug 29, 2006 1:41 pm     Reply with quote
With this chips and CCS PCH V3.249 & V4.00x all ADC library call's not work !!!
PIC18(L)F45J10 have 3 ADCON Registers, CCS will only support PIC18 devices with 2 ADCON Regsiters !?
Only as work arround its is possible the direkt BIT access to the phys. register adresses...
-> CCS: please correct this and give new "devices" file for V3.249 & all new versions
PostPosted: Tue Aug 29, 2006 2:34 pm     Reply with quote
I compiled a test program for the 18F45J10 for PCH 3.249 and looked
at the .LST file. It uses all three ADCON registers.
I suggest that you make a small test program, similar to the one
shown in this post, and see if it works:
http://www.ccsinfo.com/forum/viewtopic.php?t=26847&start=1
If it doesn't work, then post your test program.
Also, please limit the testing to vs. 3.249. I don't want to look at
vs. 4.xxx.
