but i need to make it toogle in a function with no preview edge knowledge..
how can make it happen?
Thank for help!!
Posted: Mon Aug 14, 2006 2:50 am
There must be some sort of 'knowledge'. Normally you could (for example), use:
if (input(PIB_B0)) {
//signal is high, so I want to interrupt on high to low
ext_int_edge(H_TO_L);
else ext_int_edge(L_TO_H);
//Otherwise interrupt on rising edge.
The decision can be based on whatever you want, but normally the state of the pin would be the most 'logical' decider.
