toggle ext int edge
butterfly
toggle ext int edge
PostPosted: Mon Aug 14, 2006 2:33 am     Reply with quote
I can change ext int edge with:
ext_int_edge( H_TO_L );
or
ext_int_edge( L_TO_H);
but i need to make it toogle in a function with no preview edge knowledge..
how can make it happen?
Thank for help!!
PostPosted: Mon Aug 14, 2006 2:50 am     Reply with quote
There must be some sort of 'knowledge'. Normally you could (for example), use:
if (input(PIB_B0)) {
   //signal is high, so I want to interrupt on high to low
   ext_int_edge(H_TO_L);
else ext_int_edge(L_TO_H);
//Otherwise interrupt on rising edge.
The decision can be based on whatever you want, but normally the state of the pin would be the most 'logical' decider.
PostPosted: Mon Aug 14, 2006 2:59 am     Reply with quote
Obviously, using the 'PIN', not the 'PIB'...
future
PostPosted: Mon Aug 14, 2006 5:05 am     Reply with quote
You can also use this:
struct
   unsigned char RBIP:1;
   unsigned char INT3P:1;
   unsigned char T0IP:1;
   unsigned char INTEDG3:1;
   unsigned char INTEDG2:1;
   unsigned char INTEDG1:1;
   unsigned char INTEDG0:1;
   unsigned char RBPU:1;
INTCON2bits ;
#locate INTCON2bits=0x0FF1 // pic 18f452
void main( void )
intcon2bits.intedg1++; // toggle edge
