Cam Bruce
MPLAB 6.20 and CCS PCH |
Posted: Thu May 08, 2003 10:36 pm |
I see in MicroChip's site here:
<a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank">http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm</a>
only Hi-Tech C Compiler is shown as "Supported Third Party Tool"
Has anyone tried MPLAB 6.2, and PCH 3.156 ?
I am making the move up, in an effort to move to 18F452 PICs
Cam
___________________________
Original Post ID: 14277 |
Woody Guest
Re: MPLAB 6.20 and CCS PCH |
Posted: Fri May 09, 2003 8:13 am |
<font face="Courier New" size=-1>When yun install MPLAB 6.20, one of the questions it presents is the tool set that will be used.
The CCS Tool Suite is listed; if you check this option it tells you to download the MPLAB 6.x Plugin from CCS available here:
<a href="http://www.ccsinfo.com/mplab6.exe" TARGET="_blank">http://www.ccsinfo.com/mplab6.exe</a>
:=I see in MicroChip's site here:
:= <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank">http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm</a></a></a>
:=only Hi-Tech C Compiler is shown as "Supported Third Party Tool"
:=Has anyone tried MPLAB 6.2, and PCH 3.156 ?
:=I am making the move up, in an effort to move to 18F452 PICs
:=Thanks
:=Cam</font>
Original Post ID: 14292 |
Douglas Richard
Posted: Fri May 09, 2003 9:31 am |
I have done all of the below steps and I still cannot compile from MPLAB 6.2. What I do is compile outside of 6.2 and then import my cod file. I have had no problems with 5.7.
Has anyone been able to compile within 6.2? Any help would be appreciated.
:=<font face="Courier New" size=-1>When yun install MPLAB 6.20, one of the questions it presents is the tool set that will be used.
:=The CCS Tool Suite is listed; if you check this option it tells you to download the MPLAB 6.x Plugin from CCS available here:
:= <a href="http://www.ccsinfo.com/mplab6.exe" TARGET="_blank"> <a href="http://www.ccsinfo.com/mplab6.exe" TARGET="_blank">http://www.ccsinfo.com/mplab6.exe</a></a>
:=:=I see in MicroChip's site here:
:=:= <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank">http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm</a></a></a></a>
:=:=only Hi-Tech C Compiler is shown as "Supported Third Party Tool"
:=:=Has anyone tried MPLAB 6.2, and PCH 3.156 ?
:=:=I am making the move up, in an effort to move to 18F452 PICs
:=:=Thanks
:=:=Cam</font>
Original Post ID: 14298 |
aaron
Posted: Fri May 09, 2003 12:31 pm |
Compiling from MPLAB 6.2 and with the latest PCH is working fine here. I installed MPLAB, installed PCH and then installed the MPLAB tool from CCS to integrate them both. I then created a new project and selected the CCS compiler instead of MPASM (had to click the show all tools button to make CCS show up). Added a quick and simple hello world program and jammed the build all button in MPLAB.... it called the compiler and compiled up fine.
Aaron
:=I have done all of the below steps and I still cannot compile from MPLAB 6.2. What I do is compile outside of 6.2 and then import my cod file. I have had no problems with 5.7.
:=Has anyone been able to compile within 6.2? Any help would be appreciated.
:=:=<font face="Courier New" size=-1>When yun install MPLAB 6.20, one of the questions it presents is the tool set that will be used.
:=:=The CCS Tool Suite is listed; if you check this option it tells you to download the MPLAB 6.x Plugin from CCS available here:
:=:= <a href="http://www.ccsinfo.com/mplab6.exe" TARGET="_blank"> <a href="http://www.ccsinfo.com/mplab6.exe" TARGET="_blank"> <a href="http://www.ccsinfo.com/mplab6.exe" TARGET="_blank">http://www.ccsinfo.com/mplab6.exe</a></a></a>
:=:=:=I see in MicroChip's site here:
:=:=:= <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank">http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm</a></a></a></a></a>
:=:=:=only Hi-Tech C Compiler is shown as "Supported Third Party Tool"
:=:=:=Has anyone tried MPLAB 6.2, and PCH 3.156 ?
:=:=:=I am making the move up, in an effort to move to 18F452 PICs
:=:=:=Thanks
:=:=:=Cam</font>
Original Post ID: 14311 |
Lifespeed Guest
Posted: Fri May 09, 2003 4:10 pm |
So, is it best to compile from MPLAB 6.2 instead of the PCW from CCS? Or do you do it that way because you don't have PCW?
Will MPLAB debugger debug the C code well, breakpoints, etc?
- Lifespeed
:=Compiling from MPLAB 6.2 and with the latest PCH is working fine here. I installed MPLAB, installed PCH and then installed the MPLAB tool from CCS to integrate them both. I then created a new project and selected the CCS compiler instead of MPASM (had to click the show all tools button to make CCS show up). Added a quick and simple hello world program and jammed the build all button in MPLAB.... it called the compiler and compiled up fine.
:=Aaron
Original Post ID: 14324 |
Douglas Richard
Posted: Mon May 12, 2003 7:10 am |
Did you install everything in the same directory (MPLAB 6.2, CCS, your .c and .h files)?
:=Aaron
Original Post ID: 14372 |
Aaron R Guest
Posted: Tue May 13, 2003 7:19 pm |
CCS was installed in the defaults directory (program files/picc) and mplab was in its default location (program files/mplab). The C files were created in a tmp directory at c:\temp.
There wasn't anything tricky. It just worked. By the way, it was with the 3.156 compiler. I've since tried the 3.158 and it worked fine also.
Aaron
:=Did you install everything in the same directory (MPLAB 6.2, CCS, your .c and .h files)?
:=:=Compiling from MPLAB 6.2 and with the latest PCH is working fine here. I installed MPLAB, installed PCH and then installed the MPLAB tool from CCS to integrate them both. I then created a new project and selected the CCS compiler instead of MPASM (had to click the show all tools button to make CCS show up). Added a quick and simple hello world program and jammed the build all button in MPLAB.... it called the compiler and compiled up fine.
:=:=Aaron
Original Post ID: 14428 |
Aaron R Guest
Posted: Tue May 13, 2003 7:23 pm |
The only advantage to using MPLAB is that I had access to my picstart+ programmer I suppose. And the fact that I don't have a license for the PCW tools. <grin>
If you aren't using the Microchip programmer tools (for instance, if you are using a bootloader instead), then the PCW IDE will likely work better for you (easy access to help, wizard, etc...). I'm able to simulate the C code under MPLAB with breakpoints and whatnot without a problem. I have no idea if that is available from the CCS IDE or not.
Aaron
:=So, is it best to compile from MPLAB 6.2 instead of the PCW from CCS? Or do you do it that way because you don't have PCW?
:=Will MPLAB debugger debug the C code well, breakpoints, etc?
:=- Lifespeed
:=:=Aaron
Original Post ID: 14429 |
Posted: Wed Aug 09, 2006 4:27 am |
Douglas Richard wrote: | Did you install everything in the same directory (MPLAB 6.2, CCS, your .c and .h files)?
:=Aaron
