MPLAB 6.20 and CCS PCH
Cam Bruce
PostPosted: Thu May 08, 2003 10:36 pm     Reply with quote
I see in MicroChip's site here:
<a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank">http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm</a>
only Hi-Tech C Compiler is shown as "Supported Third Party Tool"
Has anyone tried MPLAB 6.2, and PCH 3.156 ?
I am making the move up, in an effort to move to 18F452 PICs
Cam
___________________________
Original Post ID: 14277
Woody
Re: MPLAB 6.20 and CCS PCH
PostPosted: Fri May 09, 2003 8:13 am     Reply with quote
<font face="Courier New" size=-1>When yun install MPLAB 6.20, one of the questions it presents is the tool set that will be used.
The CCS Tool Suite is listed; if you check this option it tells you to download the MPLAB 6.x Plugin from CCS available here:
<a href="http://www.ccsinfo.com/mplab6.exe" TARGET="_blank">http://www.ccsinfo.com/mplab6.exe</a>
:=I see in MicroChip's site here:
:= <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank">http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm</a></a></a>
:=only Hi-Tech C Compiler is shown as "Supported Third Party Tool"
:=Has anyone tried MPLAB 6.2, and PCH 3.156 ?
:=I am making the move up, in an effort to move to 18F452 PICs
:=Thanks
:=Cam</font>
Original Post ID: 14292
Douglas Richard
PostPosted: Fri May 09, 2003 9:31 am     Reply with quote
I have done all of the below steps and I still cannot compile from MPLAB 6.2. What I do is compile outside of 6.2 and then import my cod file. I have had no problems with 5.7.
Has anyone been able to compile within 6.2? Any help would be appreciated.
:=<font face="Courier New" size=-1>When yun install MPLAB 6.20, one of the questions it presents is the tool set that will be used.
:=The CCS Tool Suite is listed; if you check this option it tells you to download the MPLAB 6.x Plugin from CCS available here:
:= <a href="http://www.ccsinfo.com/mplab6.exe" TARGET="_blank"> <a href="http://www.ccsinfo.com/mplab6.exe" TARGET="_blank">http://www.ccsinfo.com/mplab6.exe</a></a>
:=:=I see in MicroChip's site here:
:=:= <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank">http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm</a></a></a></a>
:=:=only Hi-Tech C Compiler is shown as "Supported Third Party Tool"
:=:=Has anyone tried MPLAB 6.2, and PCH 3.156 ?
:=:=I am making the move up, in an effort to move to 18F452 PICs
:=:=Thanks
:=:=Cam</font>
Original Post ID: 14298
aaron
PostPosted: Fri May 09, 2003 12:31 pm     Reply with quote
Compiling from MPLAB 6.2 and with the latest PCH is working fine here. I installed MPLAB, installed PCH and then installed the MPLAB tool from CCS to integrate them both. I then created a new project and selected the CCS compiler instead of MPASM (had to click the show all tools button to make CCS show up). Added a quick and simple hello world program and jammed the build all button in MPLAB.... it called the compiler and compiled up fine.
Aaron
:=I have done all of the below steps and I still cannot compile from MPLAB 6.2. What I do is compile outside of 6.2 and then import my cod file. I have had no problems with 5.7.
:=Has anyone been able to compile within 6.2? Any help would be appreciated.
:=:=<font face="Courier New" size=-1>When yun install MPLAB 6.20, one of the questions it presents is the tool set that will be used.
:=:=The CCS Tool Suite is listed; if you check this option it tells you to download the MPLAB 6.x Plugin from CCS available here:
:=:= <a href="http://www.ccsinfo.com/mplab6.exe" TARGET="_blank"> <a href="http://www.ccsinfo.com/mplab6.exe" TARGET="_blank"> <a href="http://www.ccsinfo.com/mplab6.exe" TARGET="_blank">http://www.ccsinfo.com/mplab6.exe</a></a></a>
:=:=:=I see in MicroChip's site here:
:=:=:= <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank"> <a href="http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm" TARGET="_blank">http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/index.htm</a></a></a></a></a>
:=:=:=only Hi-Tech C Compiler is shown as "Supported Third Party Tool"
:=:=:=Has anyone tried MPLAB 6.2, and PCH 3.156 ?
:=:=:=I am making the move up, in an effort to move to 18F452 PICs
:=:=:=Thanks
:=:=:=Cam</font>
Original Post ID: 14311
Lifespeed
PostPosted: Fri May 09, 2003 4:10 pm     Reply with quote
So, is it best to compile from MPLAB 6.2 instead of the PCW from CCS? Or do you do it that way because you don't have PCW?
Will MPLAB debugger debug the C code well, breakpoints, etc?
- Lifespeed
:=Compiling from MPLAB 6.2 and with the latest PCH is working fine here. I installed MPLAB, installed PCH and then installed the MPLAB tool from CCS to integrate them both. I then created a new project and selected the CCS compiler instead of MPASM (had to click the show all tools button to make CCS show up). Added a quick and simple hello world program and jammed the build all button in MPLAB.... it called the compiler and compiled up fine.
:=Aaron
Original Post ID: 14324
Douglas Richard
PostPosted: Mon May 12, 2003 7:10 am     Reply with quote
Did you install everything in the same directory (MPLAB 6.2, CCS, your .c and .h files)?
:=Aaron
Original Post ID: 14372
Aaron R
PostPosted: Tue May 13, 2003 7:19 pm     Reply with quote
CCS was installed in the defaults directory (program files/picc) and mplab was in its default location (program files/mplab). The C files were created in a tmp directory at c:\temp.
There wasn't anything tricky. It just worked. By the way, it was with the 3.156 compiler. I've since tried the 3.158 and it worked fine also.
Aaron
:=Did you install everything in the same directory (MPLAB 6.2, CCS, your .c and .h files)?
:=:=Compiling from MPLAB 6.2 and with the latest PCH is working fine here. I installed MPLAB, installed PCH and then installed the MPLAB tool from CCS to integrate them both. I then created a new project and selected the CCS compiler instead of MPASM (had to click the show all tools button to make CCS show up). Added a quick and simple hello world program and jammed the build all button in MPLAB.... it called the compiler and compiled up fine.
:=:=Aaron
Original Post ID: 14428
Aaron R
PostPosted: Tue May 13, 2003 7:23 pm     Reply with quote
The only advantage to using MPLAB is that I had access to my picstart+ programmer I suppose. And the fact that I don't have a license for the PCW tools. <grin>
If you aren't using the Microchip programmer tools (for instance, if you are using a bootloader instead), then the PCW IDE will likely work better for you (easy access to help, wizard, etc...). I'm able to simulate the C code under MPLAB with breakpoints and whatnot without a problem. I have no idea if that is available from the CCS IDE or not.
Aaron
:=So, is it best to compile from MPLAB 6.2 instead of the PCW from CCS? Or do you do it that way because you don't have PCW?
:=Will MPLAB debugger debug the C code well, breakpoints, etc?
:=- Lifespeed
:=:=Aaron
Original Post ID: 14429
PostPosted: Wed Aug 09, 2006 4:27 am     Reply with quote
:=Aaron
