More typemod limitations?
future
PostPosted: Sat Jul 29, 2006 2:28 pm     Reply with quote
Hi all,
I've stripped down the program to show the problem, "typemoded" variables won't accept some operations.
   #include "18f452.h"
   #zero_ram
   #opt      11
   #use      delay( clock=40000000 )
   #fuses    H4, CPD, WDT1, PUT, PROTECT, CPB, WRT, WRTC, NOLVP, BROWNOUT
   void DATAEPROM_Write  ( int32 addr, int8 *ram, int nbytes );
   void DATAEPROM_Read   ( int32 addr, int8 *ram, int nbytes );
   typemod <, DATAEPROM_Read, DATAEPROM_Write, 0x00000000, 0x000000FF > DATAEPROM ;
   void DATAEPROM_Write( int32 addr, int8 *ram, int nbytes )          //
//       EEADDR = addr;                                               //
//       EEDATA = ram;                                                //
   void DATAEPROM_Read( int32 addr, int8 *ram, int nbytes )           //
   struct
      unsigned char test1;
      unsigned char test2;
      unsigned char test3;
      unsigned char test4;
      unsigned char test5;
      unsigned char test6;
      unsigned char test7;
   DATAEPROM TestStruct;
main( void )
  char temp;
  TestStruct.test1 = 2;
  Temp = TestStruct.test2 >>1;
This seems to kill the advantages of using external ram.
PostPosted: Sun Jul 30, 2006 2:39 am     Reply with quote
Use the #type declaration, rather than trying to allocate the structure as you show. The compiler seems to get confused when you use a 'typemod' declaration on more complex types. So:
#type default=DATAEEPROM
   struct
   } TestStruct;
#type default=
Makes it work.
future
PostPosted: Sun Jul 30, 2006 11:42 am     Reply with quote
It still doesn't work, it should be DATAEPROM instead of DATAEEPROM.
PostPosted: Sun Jul 30, 2006 2:29 pm     Reply with quote
Since the code uses 'EEDATA', I must admit I changed it to refer to EEPROM. :-)
The odder thing, is that I actually compiled a demo, and looked through the code, and it appeared 'sensible', but now it refuses to compile like your earlier attempt. It appears that the return must be fed to a temporary register, rather than handled directly. A small limitation, but one that seems unnecessary, you would think that the normal 'scratch' process should handle this...
future
PostPosted: Sun Jul 30, 2006 2:57 pm     Reply with quote
If I change the struct for an array and #define names for the variables it works. The result is ugly but does the job.
char TestArray[7];
#define test1 0
#define test1 1
TestStruct.test1 turns to TestArray[test1]
