future
More typemod limitations? |
Posted: Sat Jul 29, 2006 2:28 pm |
Hi all,
I've stripped down the program to show the problem, "typemoded" variables won't accept some operations.
Code: | #include "18f452.h"
#zero_ram
#opt 11
#use delay( clock=40000000 )
#fuses H4, CPD, WDT1, PUT, PROTECT, CPB, WRT, WRTC, NOLVP, BROWNOUT
void DATAEPROM_Write ( int32 addr, int8 *ram, int nbytes );
void DATAEPROM_Read ( int32 addr, int8 *ram, int nbytes );
typemod <, DATAEPROM_Read, DATAEPROM_Write, 0x00000000, 0x000000FF > DATAEPROM ;
void DATAEPROM_Write( int32 addr, int8 *ram, int nbytes ) //
// EEADDR = addr; //
// EEDATA = ram; //
void DATAEPROM_Read( int32 addr, int8 *ram, int nbytes ) //
struct
unsigned char test1;
unsigned char test2;
unsigned char test3;
unsigned char test4;
unsigned char test5;
unsigned char test6;
unsigned char test7;
DATAEPROM TestStruct;
main( void )
char temp;
TestStruct.test1 = 2;
Temp = TestStruct.test2 >>1;
This seems to kill the advantages of using external ram. |
Posted: Sun Jul 30, 2006 2:39 am |
Use the #type declaration, rather than trying to allocate the structure as you show. The compiler seems to get confused when you use a 'typemod' declaration on more complex types. So:
#type default=DATAEEPROM
struct
} TestStruct;
#type default=
Makes it work.
future
Posted: Sun Jul 30, 2006 11:42 am |
It still doesn't work, it should be DATAEPROM instead of DATAEEPROM. |
Posted: Sun Jul 30, 2006 2:29 pm |
Since the code uses 'EEDATA', I must admit I changed it to refer to EEPROM. :-)
The odder thing, is that I actually compiled a demo, and looked through the code, and it appeared 'sensible', but now it refuses to compile like your earlier attempt. It appears that the return must be fed to a temporary register, rather than handled directly. A small limitation, but one that seems unnecessary, you would think that the normal 'scratch' process should handle this...
future
Posted: Sun Jul 30, 2006 2:57 pm |
If I change the struct for an array and #define names for the variables it works. The result is ugly but does the job.
char TestArray[7];
#define test1 0
#define test1 1
TestStruct.test1 turns to TestArray[test1] |
