I looking the good way to control the brightness on each LED conected to the output of 74595 ? individualy ?
I need to control 4 x 74595 ( 32 LED )
Alain Tanguay
Posted: Sun Jul 23, 2006 8:33 pm
you need to use PWM.. pulse width modulation
the outputs can only be on or off at a time, so the trick is to let tem off for some time and on.. the ratio between on/(off+on) is called duty cicle, and defines the bright... of course toff+ton must be a very short time, like 1/60 sec.
