CCS config bits vs datasheet's |
Posted: Wed May 14, 2008 10:42 am |
When using this statement:
#fuses MCLR,WDT,PROTECT
The compiler generates this in the LST file:
Configuration Fuses:
Word 1: 0FF7 MCLR PROTECT WDT
However, the data sheet for the PIC10F200 specifies the configuration word as:
bit 11-5 Unimplemented: Read as ‘0’
bit 4 MCLRE: GP3/MCLR Pin Function Select bit
1 = GP3/MCLR pin function is MCLR
0 = GP3/MCLR pin function is digital I/O, MCLR internally tied to VDD
bit 3 CP: Code Protection bit
1 = Code protection off
0 = Code protection on
bit 2 WDTE: Watchdog Timer Enable bit
1 = WDT enabled
0 = WDT disabled
bit 1-0 Reserved: Read as ‘0’
So for MCLR, PROTECT, WDTE, shouldn't the word be 0000 0001 0100?
or 0x014? |
Posted: Wed May 14, 2008 2:27 pm |
Says 'read as 0', not that they have to be written as '0'. So any permutation, with:
xxxx xxxx xxx1 01xx
Posted: Wed May 14, 2008 3:04 pm |
Very interesting -Thanks! |
