Does it refer to a pins of the any ports?If my opinion is right
,which ports and also which pins?If my opinion is wrong,why this commend used?I couldn't understand:sad:
Thanks a lot....
rberek
Joined: 10 Jan 2005 Posts: 207 Location: Ottawa, Canada
Posted: Fri May 19, 2006 6:21 am
A line like:
#bit y3=9.1
means that you are giving a name to bit 1 of memory address 9.
The line #bit x3 = x.3 indicates that somewhere else in the code, a memory address was given the name x and bit 3 of this address will be given the name x3.
LEVENT
Posted: Fri May 19, 2006 7:00 am
thanks,I fined that,memory address of 9 is refer to PORTE
