simple question
LEVENT
simple question
PostPosted: Fri May 19, 2006 5:56 am     Reply with quote
can anybody explane me purpose of this code:
#bit x3=x.3
#bit x2=x.2
#bit x1=x.1
#bit x0=x.0
#bit y3=5.5
#bit y2=9.0
#bit y1=9.1
#bit y0=9.2
#bit rf=8.3
#bit START=8.0
#bit STOP=8.2
#bit KLEPE=7.3
Does it refer to a pins of the any ports?If my opinion is right
,which ports and also which pins?If my opinion is wrong,why this commend used?I couldn't understand:sad:
Thanks a lot....
rberek
PostPosted: Fri May 19, 2006 6:21 am     Reply with quote
A line like:
#bit y3=9.1
means that you are giving a name to bit 1 of memory address 9.
The line #bit x3 = x.3 indicates that somewhere else in the code, a memory address was given the name x and bit 3 of this address will be given the name x3.
LEVENT
PostPosted: Fri May 19, 2006 7:00 am     Reply with quote
thanks,I fined that,memory address of 9 is refer to PORTE Very Happy
