andreluizeng
| pic18f4525 |
Posted: Tue May 16, 2006 4:47 pm |
hi people
my compiler's version is 3.221 and im having problems with pic 18f4525
does it compiler's version compiles softwares for 18f4525 ??
and which address i need to use to pre-write values on eeprom ??
0x2100 ??
att. _________________ Andre |
andreluizeng
Posted: Tue May 16, 2006 5:08 pm |
thanks.. but doesnt work good
#rom 0xF0000 = {0x00, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00}
this is the values that i need, and after program the pic, i read again and got these values:
address 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
0000 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00
0001 00 00 00 ff ff ff ff....
whats wrong ? _________________ Andre |
Posted: Tue May 16, 2006 5:17 pm |
One important key to success in electronics is attention to detail. |
andreluizeng
i wrote wrong,
#rom 0xf000000....
regards. _________________ Andre |
andreluizeng
Posted: Tue May 16, 2006 5:18 pm |
my keyboard sux..
i put #rom 0xf00000
yeah... _________________ Andre |
andreluizeng
Posted: Tue May 16, 2006 5:32 pm |
hello again.
the eeprom's data size of 18f4525 is 2 bytes long..
now its working..
thanks _________________ Andre |
andreluizeng
Posted: Tue May 16, 2006 5:47 pm |
hey pcm, thanks for the help..
so.. i have 2 more problems.
the pic is reseting when i use set_pwm1_duty (), and timer 0 stops working.
do you have some link talking about this ?
regards.. _________________ Andre |
Posted: Tue May 16, 2006 6:13 pm |
Disconnect the external components from the PWM output pin
on the PIC, and run the program. Does the PIC still reset ? |
andreluizeng
Posted: Tue May 16, 2006 6:38 pm |
pcm, no the pic stops reset, but i was using a 16f877on this project and its working good, i had to change because 877 hasnt program memory enough to my application..
what i have to do to is works ? _________________ Andre |
Posted: Tue May 16, 2006 6:54 pm |
It probably means that when you turn on the PWM pulses, the external
circuit draws too much current and loads down your power supply to
a voltage level which is below the Brownout Voltage setting. This will
cause the PIC to reset.
There could be some other reason. But look closely at your external
circuit. Look for problems with it. |
andreluizeng
Posted: Tue May 16, 2006 6:56 pm |
ok, i will change de value of my brownout...
regards _________________ Andre |
Posted: Wed May 17, 2006 12:18 am |
My suggestion was really to check if a Brownout reset is occuring when
the PWM output is enabled. If so, then improve the power supply so it
can supply enough current and keep proper regulation of the Vdd voltage. |
andreluizeng
Posted: Wed May 17, 2006 10:33 am |
pcm,
im going to check it, but i dont really think that is the problem,
i changed the value of brownout detect to 2.1V and still not working.
but when i disconnect the load it doesnt happen.
maybe my power supply is not working well, but it was working with the same code on 16f877, just with 18f4525 im having this problem.
the difference is that 16f877 i dont need to set the value of brownout, and the 18f4525 i do.
regards.
(sorry for my english) _________________ Andre |
