pic18f4525
andreluizeng
View user's profile Send private message Send e-mail MSN Messenger
pic18f4525
PostPosted: Tue May 16, 2006 4:47 pm     Reply with quote
hi people
my compiler's version is 3.221 and im having problems with pic 18f4525
does it compiler's version compiles softwares for 18f4525 ??
and which address i need to use to pre-write values on eeprom ??
0x2100 ??
att.
Andre
PostPosted: Tue May 16, 2006 4:55 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=23208
andreluizeng
PostPosted: Tue May 16, 2006 5:08 pm     Reply with quote
thanks.. but doesnt work good
#rom 0xF0000 = {0x00, 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00}
this is the values that i need, and after program the pic, i read again and got these values:
address 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
0000 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00
0001 00 00 00 ff ff ff ff....
whats wrong ?
Andre
PostPosted: Tue May 16, 2006 5:17 pm     Reply with quote
#rom 0xF0000
One important key to success in electronics is attention to detail.
andreluizeng
i wrote wrong,
#rom 0xf000000....
regards.
Andre
andreluizeng
PostPosted: Tue May 16, 2006 5:18 pm     Reply with quote
my keyboard sux..
i put #rom 0xf00000
yeah...
Andre
andreluizeng
PostPosted: Tue May 16, 2006 5:32 pm     Reply with quote
hello again.
the eeprom's data size of 18f4525 is 2 bytes long..
now its working..
thanks
Andre
PostPosted: Tue May 16, 2006 5:36 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=25373
andreluizeng
PostPosted: Tue May 16, 2006 5:47 pm     Reply with quote
hey pcm, thanks for the help..
so.. i have 2 more problems.
the pic is reseting when i use set_pwm1_duty (), and timer 0 stops working.
do you have some link talking about this ?
regards..
Andre
PostPosted: Tue May 16, 2006 6:13 pm     Reply with quote
Disconnect the external components from the PWM output pin
on the PIC, and run the program. Does the PIC still reset ?
andreluizeng
PostPosted: Tue May 16, 2006 6:38 pm     Reply with quote
pcm, no the pic stops reset, but i was using a 16f877on this project and its working good, i had to change because 877 hasnt program memory enough to my application..
what i have to do to is works ?
Andre
PostPosted: Tue May 16, 2006 6:54 pm     Reply with quote
It probably means that when you turn on the PWM pulses, the external
circuit draws too much current and loads down your power supply to
a voltage level which is below the Brownout Voltage setting. This will
cause the PIC to reset.
There could be some other reason. But look closely at your external
circuit. Look for problems with it.
andreluizeng
PostPosted: Tue May 16, 2006 6:56 pm     Reply with quote
ok, i will change de value of my brownout...
regards
Andre
PostPosted: Wed May 17, 2006 12:18 am     Reply with quote
My suggestion was really to check if a Brownout reset is occuring when
the PWM output is enabled. If so, then improve the power supply so it
can supply enough current and keep proper regulation of the Vdd voltage.
andreluizeng
PostPosted: Wed May 17, 2006 10:33 am     Reply with quote
pcm,
im going to check it, but i dont really think that is the problem,
i changed the value of brownout detect to 2.1V and still not working.
but when i disconnect the load it doesnt happen.
maybe my power supply is not working well, but it was working with the same code on 16f877, just with 18f4525 im having this problem.
the difference is that 16f877 i dont need to set the value of brownout, and the 18f4525 i do.
regards.
(sorry for my english)
Andre
