Noritake VFD CU20045SCPB-T23A display with HW USART
The Puma
PostPosted: Sat May 13, 2006 3:26 pm     Reply with quote
Did anyone has experience how to drive a this vfd display
with HW USART
BR = 19200 BPS
Non Parity
Please give a sample program how to do
The Puma
PostPosted: Mon May 15, 2006 12:14 pm     Reply with quote
I have working sofar with this code
#include <18F4620.h>
#use rs232(baud=19200,parity=n,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#fuses HS,NOWDT,NOBROWNOUT,NOPUT,NOLVP,DEBUG,NOSTVREN,NOPROTECT
#include <cu20045scpb-t23a.h>
   output_low(CU20045SCPB_BUSY);
   printf("TEST");
   delay_ms(1);
   output_high(CU20045SCPB_BUSY);
#define CU20045SCPB_BUSY  PIN_C0
void vfd_init() {
   delay_ms(2);
void vfd_send_byte(byte n) {
   printf(n);
   delay_ms(2);
void vfd_putc(char c) {
   switch(c) {
      default  : vfd_send_byte(c); break;
But if i change to that it did't work anymore
What is the problem
   vfd_init();
   vfd_putc("TEST");
