		| Author | Message |
		| emh203@psu.edu
				| Function Pointers? |
				|  Posted: Fri May 05, 2006 4:01 pm |   |
				| Does CCS allow the use of function pointers?   For example, I want to pass a function pointer in another function like so (standard C):
 unsigned char RegisterMessageDelegate(int  (*MessageDelegate)(unsigned char *,unsigned short));
 The compiler will not allow this.  Is there another way of using function pointers with this compiler?
 Thanks,
 ELi
		| treitmey
		| emh203@psu.edu
				| No, not pointers to variables, pointers to Function |
				|  Posted: Mon May 08, 2006 7:26 am |   |
				| QSORT Only appears to be a standard pointer (for memory/variables).  What I need is support for pointers to Functions.
 -ELi
		| Ttelmah Guest
				|  Posted: Mon May 08, 2006 7:38 am |   |
				| No, QSORT, uses pointers to functions, not just to values. There is a function 'ascending', and a function 'descending', and these are passed to the qsort function as the 'compare' item. Look again.
		| Mark
				|  Posted: Mon May 08, 2006 7:59 am |   |
				| You can also use the search feature to find your answers.  Here is a snippet from an old post
  	  | Code: |  	  | // Typedef for our function pointer
 typedef int (*pFunc)(void);
 int myfunction(void)
 return (1);
 int i;
 pFunc ptrtofunc;
 // Dummy initialization to keep the compiler from complaining
 ptrtofunc = myfunction;
 // Call the function
 i=(*ptrtofunc)();
 while( TRUE )
