Function Pointers?
emh203@psu.edu
Function Pointers?
PostPosted: Fri May 05, 2006 4:01 pm     Reply with quote
Does CCS allow the use of function pointers? For example, I want to pass a function pointer in another function like so (standard C):
unsigned char RegisterMessageDelegate(int (*MessageDelegate)(unsigned char *,unsigned short));
The compiler will not allow this. Is there another way of using function pointers with this compiler?
Thanks,
ELi
treitmey
PostPosted: Fri May 05, 2006 8:02 pm     Reply with quote
It use to say just use a switch statment.
But now it looks like you can do it the ansi C way.
http://www.ccsinfo.com/faq.php?page=pointer_to_function
emh203@psu.edu
No, not pointers to variables, pointers to Function
PostPosted: Mon May 08, 2006 7:26 am     Reply with quote
QSORT Only appears to be a standard pointer (for memory/variables). What I need is support for pointers to Functions.
-ELi
PostPosted: Mon May 08, 2006 7:38 am     Reply with quote
No, QSORT, uses pointers to functions, not just to values. There is a function 'ascending', and a function 'descending', and these are passed to the qsort function as the 'compare' item. Look again.
Mark
PostPosted: Mon May 08, 2006 7:59 am     Reply with quote
You can also use the search feature to find your answers. Here is a snippet from an old post
// Typedef for our function pointer
typedef int (*pFunc)(void);
int myfunction(void)
  return (1);
  int i;
  pFunc ptrtofunc;
  // Dummy initialization to keep the compiler from complaining
  ptrtofunc = myfunction;
  // Call the function
  i=(*ptrtofunc)();
  while( TRUE )
