wrong characters in lcd without disbable_global
Calamar
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Tue Apr 25, 2006 7:01 am     Reply with quote
This code works
compiler versions
3.245
3.222
#include <18f452.h>
#fuses HS, NOWDT, PUT, NOLVP, BORV42, NOPROTECT, CCP2B3
#use delay (clock=10000000)
#include <lcd.h>
#bit TMR3_flag = 0xfa1.0 // flag bit from TMR3
int32   TMR3_pulses = 0;
int32   frecuency = 0;
int      TMR3_rollOver;
char    line_1[16] = "";
int contador;
#INT_TIMER3
tmr3_isr()
   TMR3_rollOver++;
#INT_CCP2
void ccp2_isr()
   static int32 rollOver_amount = 65536;
   TMR3_pulses = rollOver_amount * (int32)TMR3_rollOver;
   TMR3_pulses += (int32) CCP_2;
   frecuency = 400000000 / TMR3_pulses;
   TMR3_rollOver  = 0;
   TMR3_flag = false;
   set_timer3(0);
   int16 Counter;
   SET_TIMER3(0);
   SETUP_TIMER_3(T3_DIV_BY_1|T3_INTERNAL);
   SETUP_CCP2(CCP_CAPTURE_DIV_16|CCP_USE_TIMER3);
   ENABLE_INTERRUPTS(INT_CCP2);
   ENABLE_INTERRUPTS(INT_TIMER3);
   ENABLE_INTERRUPTS(GLOBAL);
   lcd_init();
   counter = 1000;
   while(true)
      lcd_gotoxy(1,1);
      counter--;
      if(!counter)
         disable_interrupts(global);
         printf(lcd_putc, "f = %6lu     ",frecuency);
         enable_interrupts(global);
Wrong charater apper when itsnt
disable de global interrupt:
//         disable_interrupts(global);
//         enable_interrupts(global);
any idea ?
Best Regards
Daniel H. Sagarra
La Plata (Argentina)
PostPosted: Tue Apr 25, 2006 8:50 am     Reply with quote
This code do the same, just
uncomment disable_interrrups(gloabal)
and work Shocked
#include <18f452.h>
int      TMR3_rollOver;
char    line_1[32] = "";
int contador;
#INT_CCP2
void ccp2_isr()
   TMR3_rollOver  = 0;
   TMR3_flag = false;
   set_timer3(0);
#include <lcd.h>
   SET_TIMER3(0);
   lcd_init();
   while(true)
       lcd_gotoxy(1,1);
//      disable_interrups(gloabal);
      sprintf(line_1, "f = %6lu     \nHola la prerinola",frecuency);
      enable_interrups(gloabal);
      printf(lcd_putc,"%s", line_1);
PostPosted: Tue Apr 25, 2006 9:03 am     Reply with quote
sorry I miss copy&paste this ISR in above message
from my code;
#INT_TIMER3
tmr3_isr()
   TMR3_rollOver++;
PostPosted: Tue Apr 25, 2006 5:54 pm     Reply with quote
What about that ???
Address      Symbol Name                         Value
     001D     frecuency_1                                            0x00001AD4
     0026     line_1                              "f =   686f
Hello World"
     0026     [0]                                                             f
     0027     [1]
     0028     [2]                                                             =
     0029     [3]
     002A     [4]
     002B     [5]
     002C     [6]                                                             6
     002D     [7]                                                             8
     002E     [8]                                                             6
     002F     [9]                                                             f
     0030     [10]
     0031     [11]
     0032     [12]
     0033     [13]
     0034     [14]
     0035     [15]                                                            .
     0036     [16]                                                            H
     0037     [17]                                                            e
     0038     [18]                                                            l
     0039     [19]                                                            l
     003A     [20]                                                            o
     003B     [21]
     003C     [22]                                                            W
     003D     [23]                                                            o
     003E     [24]                                                            r
     003F     [25]                                                            l
     0040     [26]                                                            d
     0041     [27]                                                            .
     0042     [28]                                                            .
     0043     [29]                                                            .
     0044     [30]                                                            .
     0045     [31]                                                            .
A break was insterted in delay_ms, runing several
times.... and it fail (686f, f->? )
the code:
#include <18f452.h>
int32   frecuency_1 = 0;
int      TMR3_rollOver;
int1    write_enable = 0;
#INT_TIMER3
tmr3_isr()
   TMR3_rollOver++;
#INT_CCP2
void ccp2_isr()
   TMR3_rollOver  = 0;
   TMR3_flag = false;
   set_timer3(0);
   if(write_enable) frecuency_1 = frecuency;
#include <lcd.h>
   SET_TIMER3(0);
   lcd_init();
   while(true)
      lcd_gotoxy(1,1);
      write_enable = false;
      sprintf(line_1, "f = %6lu     \nHello World",frecuency_1);
      write_enable = true;
      lcd_gotoxy(6,1);
