Calamar
Joined: 07 Sep 2003 Posts: 60 Location: Buenos Aires (Argentina)
wrong characters in lcd without disbable_global |
Posted: Tue Apr 25, 2006 7:01 am |
This code works
compiler versions
3.245
3.222
#include <18f452.h>
#fuses HS, NOWDT, PUT, NOLVP, BORV42, NOPROTECT, CCP2B3
#use delay (clock=10000000)
#include <lcd.h>
#bit TMR3_flag = 0xfa1.0 // flag bit from TMR3
int32 TMR3_pulses = 0;
int32 frecuency = 0;
int TMR3_rollOver;
char line_1[16] = "";
int contador;
#INT_TIMER3
tmr3_isr()
TMR3_rollOver++;
#INT_CCP2
void ccp2_isr()
static int32 rollOver_amount = 65536;
TMR3_pulses = rollOver_amount * (int32)TMR3_rollOver;
TMR3_pulses += (int32) CCP_2;
frecuency = 400000000 / TMR3_pulses;
TMR3_rollOver = 0;
TMR3_flag = false;
set_timer3(0);
int16 Counter;
SET_TIMER3(0);
SETUP_TIMER_3(T3_DIV_BY_1|T3_INTERNAL);
SETUP_CCP2(CCP_CAPTURE_DIV_16|CCP_USE_TIMER3);
ENABLE_INTERRUPTS(INT_CCP2);
ENABLE_INTERRUPTS(INT_TIMER3);
ENABLE_INTERRUPTS(GLOBAL);
lcd_init();
counter = 1000;
while(true)
lcd_gotoxy(1,1);
counter--;
if(!counter)
disable_interrupts(global);
printf(lcd_putc, "f = %6lu ",frecuency);
enable_interrupts(global);
Wrong charater apper when itsnt
disable de global interrupt:
Code: | // disable_interrupts(global);
// enable_interrupts(global); |
any idea ? _________________ Best Regards
Daniel H. Sagarra
La Plata (Argentina) |
Posted: Tue Apr 25, 2006 8:50 am |
This code do the same, just
uncomment disable_interrrups(gloabal)
and work
Code: | #include <18f452.h>
int TMR3_rollOver;
char line_1[32] = "";
int contador;
#INT_CCP2
void ccp2_isr()
TMR3_rollOver = 0;
TMR3_flag = false;
set_timer3(0);
#include <lcd.h>
SET_TIMER3(0);
lcd_init();
while(true)
lcd_gotoxy(1,1);
// disable_interrups(gloabal);
sprintf(line_1, "f = %6lu \nHola la prerinola",frecuency);
enable_interrups(gloabal);
printf(lcd_putc,"%s", line_1);
Posted: Tue Apr 25, 2006 9:03 am |
sorry I miss copy&paste this ISR in above message
from my code;
Code: | #INT_TIMER3
tmr3_isr()
TMR3_rollOver++;
Posted: Tue Apr 25, 2006 5:54 pm |
What about that ???
Code: | Address Symbol Name Value
001D frecuency_1 0x00001AD4
0026 line_1 "f = 686f
Hello World"
0026 [0] f
0027 [1]
0028 [2] =
0029 [3]
002A [4]
002B [5]
002C [6] 6
002D [7] 8
002E [8] 6
002F [9] f
0030 [10]
0031 [11]
0032 [12]
0033 [13]
0034 [14]
0035 [15] .
0036 [16] H
0037 [17] e
0038 [18] l
0039 [19] l
003A [20] o
003B [21]
003C [22] W
003D [23] o
003E [24] r
003F [25] l
0040 [26] d
0041 [27] .
0042 [28] .
0043 [29] .
0044 [30] .
0045 [31] . |
A break was insterted in delay_ms, runing several
times.... and it fail (686f, f->? )
the code:
int32 frecuency_1 = 0;
int TMR3_rollOver;
int1 write_enable = 0;
#INT_TIMER3
tmr3_isr()
TMR3_rollOver++;
#INT_CCP2
void ccp2_isr()
TMR3_rollOver = 0;
TMR3_flag = false;
set_timer3(0);
if(write_enable) frecuency_1 = frecuency;
#include <lcd.h>
SET_TIMER3(0);
lcd_init();
while(true)
lcd_gotoxy(1,1);
write_enable = false;
sprintf(line_1, "f = %6lu \nHello World",frecuency_1);
write_enable = true;
lcd_gotoxy(6,1);
