Problem declaring a pointer
Wizard
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Wed Mar 29, 2006 4:22 pm     Reply with quote
I have no idea why I can't compile the following var declaration, I'm going to use it to display a menu in a LCD.
char *menu[]=
   " Start/Stop  Sample",
   "Show  Atmosph. Temp.",
   "Show  Corporal Temp.",
   "  Sample Settings",
   "  System Settings"
I got the "Expect }" error from the compiler, the compiler stuck after ...Sample",
Any ideas? I would say that the C sintax it's rather than correct.
Does someone know a equivalent code which will compile?
I have planed to use the var like this:
lcd_gotoxy(1,(i+1));
print_lcd(menu[command]);
Thanks,
Tomas L.
PostPosted: Wed Mar 29, 2006 4:37 pm     Reply with quote
The program shown below has the following output:
Start/Stop  Sample
Show  Atmosph. Temp.
Show  Corporal Temp.
  Sample Settings
  System Settings
#include <18F452.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOPROTECT,NOLVP
char *menu[5][21]=
  {" Start/Stop  Sample "},
  {"Show  Atmosph. Temp."},
  {"Show  Corporal Temp."},
  {"  Sample Settings   "},
  {"  System Settings   "}
int8 i;
for(i = 0; i < 5; i++)
    printf("%s\n\r", menu[i]);
