elizeu
Who to pass PIN with formal parameters of user functions |
Posted: Mon Aug 14, 2006 8:42 am |
I´m from Brazil, and have problem with this type of function
Help -me ?
Ex:
using of function :
if( myfunc(PIN_A1))
int myfunc( short int pin)
if(input(pin))
return 1;
Congratulations |
Posted: Mon Aug 14, 2006 9:09 am |
The 'key', is that the standard pin I/O functions, cannot accept variables. They are replaced 'inline', with direct I/O to the specified pin. Hence with these, you cannot pass a value to a function, specifying a pin.
However you can generate your own version of the I/O punction, that will accept a variable.
Have a look at the thread "Accessing digital I/O from within a for loop", which has references to a number of different solutions.
