Who to pass PIN with formal parameters of user functions
elizeu
PostPosted: Mon Aug 14, 2006 8:42 am     Reply with quote
I´m from Brazil, and have problem with this type of function
Help -me ?
Ex:
using of function :
if( myfunc(PIN_A1))
int myfunc( short int pin)
if(input(pin))
return 1;
Congratulations
PostPosted: Mon Aug 14, 2006 9:09 am     Reply with quote
The 'key', is that the standard pin I/O functions, cannot accept variables. They are replaced 'inline', with direct I/O to the specified pin. Hence with these, you cannot pass a value to a function, specifying a pin.
However you can generate your own version of the I/O punction, that will accept a variable.
Have a look at the thread "Accessing digital I/O from within a for loop", which has references to a number of different solutions.
PostPosted: Mon Aug 14, 2006 9:56 am     Reply with quote
Here are functions to do pin i/o, with the pin number passed as
a variable:
For 16F:
http://www.ccsinfo.com/forum/viewtopic.php?t=25280&start=4
For 18F:
http://www.ccsinfo.com/forum/viewtopic.php?t=27723&start=3
