roby Guest
question about binary code and variables |
Posted: Wed Mar 01, 2006 2:06 pm |
I need to read one bit from 3 pins A1 A2 A3. For example A1=1 A2=2 A3=3 then I need to see them as one binary number that is to say I need to put them side by side to create the number 101 and I it becomes a number to convert in decimal or to use.
how can I do?
Thanks from Italy |
Posted: Wed Mar 01, 2006 2:35 pm |
Do you mean something like this?
Code: | int8 InputValue;
InputValue = input_a() & 0b00001110; // Only get state of pins A1, A2, A3
InputValue = InputValue >> 1; // A0 is not used, so shift value 1 bit to the right
printf("InputValue = %d\n", InputValue); |
Humberto
Posted: Wed Mar 01, 2006 4:24 pm |
If what you want it is a binary representación of the type '101':
int n = 3;
printf("Binary = ");
do
if(bit_test(InputValue,3))
{putc('1'); }
{putc('0'); }
rotate_left(&InputValue,1);
}while(--n);
Humberto |
