question about binary code and variables
roby
PostPosted: Wed Mar 01, 2006 2:06 pm     Reply with quote
I need to read one bit from 3 pins A1 A2 A3. For example A1=1 A2=2 A3=3 then I need to see them as one binary number that is to say I need to put them side by side to create the number 101 and I it becomes a number to convert in decimal or to use.
how can I do?
Thanks from Italy
PostPosted: Wed Mar 01, 2006 2:35 pm     Reply with quote
Do you mean something like this?
int8 InputValue;
InputValue = input_a() & 0b00001110;  // Only get state of pins A1, A2, A3
InputValue = InputValue >> 1;         // A0 is not used, so shift value 1 bit to the right
printf("InputValue = %d\n", InputValue);
Humberto
PostPosted: Wed Mar 01, 2006 4:24 pm     Reply with quote
If what you want it is a binary representación of the type '101':
int n = 3;
 printf("Binary =  ");
 do
    if(bit_test(InputValue,3))
      {putc('1'); }
      {putc('0'); }
    rotate_left(&InputValue,1);
   }while(--n);
Humberto
