What does the moved IRQ/RESET look like in a list file?
treitmey
PostPosted: Mon Feb 13, 2006 5:58 pm     Reply with quote
I want to verify that my #build statement did what I want.
#define  FIRM_MAJOR  2
#define  FIRM_MINOR  00
#define  HARD_MAJOR  3
#define  HARD_MINOR  01
#define  PROD_ID     1
#include <18f452.h>
#define hi(x)  (*(&x+1))  //data held at addr of x + 1
#define lo(x)  (*(&x))    //data held at addr of x
#org 0x7FE1, 0x7FFF  //puts 2.00 3.01 1 (0200030101) at 0x7FF0
const char revision[] = {FIRM_MAJOR,FIRM_MINOR,HARD_MAJOR,HARD_MINOR,PROD_ID};
#org default
//===========LOADER_SIZE============//
#define LOADER_ADDR 0x20
#define LOADER_SIZE 0x200
#define LOADER_END  LOADER_ADDR + LOADER_SIZE
#build(reset=LOADER_END+2, interrupt=LOADER_END+8)
//---------------- GLOBAL VAR --------------------
int8 RX_BUF[64];
//===================== PrgmPIC =========================
//Assumes RX_BUF[0] is defined as global. char RX_BUF[256]; or at least 64
#org LOADER_ADDR,LOADER_END
#use I2C(MASTER,SDA=PIN_C4,SCL=PIN_C3,FORCE_HW,FAST,RESTART_WDT)
void PrgmPIC(void){
  int32 address;
  int8 data,size;
  #define block 64
  char *ptr_char;
  disable_interrupts(GLOBAL);
  for(address=0;address<0x7D00;address+=block){ //read 8 bytes prgm from fram
    ptr_char=&RX_BUF[0];//&RX_BUF[0] is defined as global. char RX_BUF[256];
    for(size=block;size;ptr_char++,size--){
      if(size==block){
        i2c_start();
        i2c_write((0xA0|(int8)(address>>14))&0xFE);//&0xFE forces to write
        i2c_write(hi(address));
        i2c_write(lo(address));
        i2c_start();
        i2c_write((0xA0|(int8)(address>>14))|1);//|1 forces to read
      if(size==1)
        *ptr_char=i2c_read(0);//No ack on last read of chip
        i2c_stop();
        *ptr_char=i2c_read(1);//The ack will put next data on bus
    write_program_memory(address,&RX_BUF[0],64);//write=8,erase=64
  reset_cpu();
#org default
//---------------- MAIN --------------------
void main(void){
  while(1){
    if(!input(PIN_A0)){
      PrgmPIC();
And the listing
CCS PCH C Compiler, Version 3.242, 30995               13-Feb-06 16:55
               Filename: C:\ccs\Projects\3200I\update_firmware\t_197.lst
               ROM used: 588 bytes (2%)
                         Largest free fragment is 32082
               RAM used: 69 (4%) at main() level
                         81 (5%) worst case
               Stack:    3 worst case (2 in main + 1 for interrupts)
0222:  GOTO   0264
.................... #define  FIRM_MAJOR  2
.................... #define  FIRM_MINOR  00
.................... #define  HARD_MAJOR  3
.................... #define  HARD_MINOR  01
.................... #define  PROD_ID     1
.................... #include <18f452.h>
.................... //////// Standard Header file for the PIC18F452 device ////////////////
.................... #device PIC18F452
0244:  MOVF   FF2,W
0246:  MOVWF  03
0248:  BCF    FF2.7
024A:  BSF    FA6.7
024C:  BSF    FA6.2
024E:  MOVLB  F
0250:  MOVLW  55
0252:  MOVWF  FA7
0254:  MOVLW  AA
0256:  MOVWF  FA7
0258:  BSF    FA6.1
025A:  NOP
025C:  MOVF   03,W
025E:  IORWF  FF2,F
0260:  MOVLB  0
0262:  RETLW  00
7FE0:  CLRF   FF7
7FE2:  ADDLW  F0
7FE4:  MOVWF  FF6
7FE6:  MOVLW  7F
7FE8:  ADDWFC FF7,F
7FEA:  TBLRD*+
7FEC:  MOVF   FF5,W
7FEE:  RETURN 0
7FF0:  DATA 02,00
7FF2:  DATA 03,01
7FF4:  DATA 01,00
7FF6:  RETLW  00
.................... //#nolist
.................... #list //2/13/2006 4:38PM tjr for a full list
.................... //////// Program memory: 16384x16  Data RAM: 1536  Stack: 31
.................... //////// I/O: 34   Analog Pins: 8
.................... //////// Data EEPROM: 256
.................... //////// C Scratch area: 00   ID Location: 2000
.................... //////// Fuses: LP,XT,HS,RC,EC,EC_IO,H4,RC_IO,PROTECT,NOPROTECT,OSCSEN
.................... //////// Fuses: NOOSCSEN,NOBROWNOUT,BROWNOUT,WDT1,WDT2,WDT4,WDT8,WDT16,WDT32
.................... //////// Fuses: WDT64,WDT128,WDT,NOWDT,BORV20,BORV27,BORV42,BORV45,PUT,NOPUT
.................... //////// Fuses: CCP2C1,CCP2B3,NOSTVREN,STVREN,NODEBUG,DEBUG,NOLVP,LVP,WRT
.................... //////// Fuses: NOWRT,NOWRTD,WRTD,NOWRTB,WRTB,WRTC,NOWRTC,CPD,NOCPD,CPB
.................... //////// Fuses: NOCPB,EBTR,NOEBTR,EBTRB,NOEBTRB
.................... ////////////////////////////////////////////////////////////////// I/O
.................... // Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
.................... //                         PORT_B_PULLUPS(), INPUT(),
.................... //                         OUTPUT_LOW(), OUTPUT_HIGH(),
.................... //                         OUTPUT_FLOAT(), OUTPUT_BIT()
.................... // Constants used to identify pins in the above are:
.................... #define PIN_A0  31744
.................... #define PIN_A1  31745
.................... #define PIN_A2  31746
.................... #define PIN_A3  31747
.................... #define PIN_A4  31748
.................... #define PIN_A5  31749
.................... #define PIN_A6  31750
.................... #define PIN_B0  31752
.................... #define PIN_B1  31753
.................... #define PIN_B2  31754
.................... #define PIN_B3  31755
.................... #define PIN_B4  31756
.................... #define PIN_B5  31757
.................... #define PIN_B6  31758
.................... #define PIN_B7  31759
.................... #define PIN_C0  31760
.................... #define PIN_C1  31761
.................... #define PIN_C2  31762
.................... #define PIN_C3  31763
.................... #define PIN_C4  31764
.................... #define PIN_C5  31765
.................... #define PIN_C6  31766
.................... #define PIN_C7  31767
.................... #define PIN_D0  31768
.................... #define PIN_D1  31769
.................... #define PIN_D2  31770
.................... #define PIN_D3  31771
.................... #define PIN_D4  31772
.................... #define PIN_D5  31773
.................... #define PIN_D6  31774
.................... #define PIN_D7  31775
.................... #define PIN_E0  31776
.................... #define PIN_E1  31777
.................... #define PIN_E2  31778
.................... ////////////////////////////////////////////////////////////////// Useful defines
.................... #define FALSE 0
.................... #define TRUE 1
.................... #define BYTE int
.................... #define BOOLEAN short int
.................... #define getc getch
.................... #define fgetc getch
.................... #define getchar getch
.................... #define putc putchar
.................... #define fputc putchar
.................... #define fgets gets
.................... #define fputs puts
.................... ////////////////////////////////////////////////////////////////// Control
.................... // Control Functions:  RESET_CPU(), SLEEP(), RESTART_CAUSE()
.................... // Constants returned from RESTART_CAUSE() are:
.................... #define WDT_TIMEOUT       7
.................... #define MCLR_FROM_SLEEP  11
.................... #define MCLR_FROM_RUN    15
.................... #define NORMAL_POWER_UP  12
.................... #define BROWNOUT_RESTART 14
.................... #define WDT_FROM_SLEEP   3
.................... #define RESET_INSTRUCTION 0
.................... ////////////////////////////////////////////////////////////////// Timer 0
.................... // Timer 0 (AKA RTCC)Functions: SETUP_COUNTERS() or SETUP_TIMER_0(),
.................... //                              SET_TIMER0() or SET_RTCC(),
.................... //                              GET_TIMER0() or GET_RTCC()
.................... // Constants used for SETUP_TIMER_0() are:
.................... #define RTCC_INTERNAL   0
.................... #define RTCC_EXT_L_TO_H 32
.................... #define RTCC_EXT_H_TO_L 48
.................... #define RTCC_DIV_1      8
.................... #define RTCC_DIV_2      0
.................... #define RTCC_DIV_4      1
.................... #define RTCC_DIV_8      2
.................... #define RTCC_DIV_16     3
.................... #define RTCC_DIV_32     4
.................... #define RTCC_DIV_64     5
.................... #define RTCC_DIV_128    6
.................... #define RTCC_DIV_256    7
.................... #define RTCC_OFF        0x80
.................... #define RTCC_8_BIT      0x40
.................... // Constants used for SETUP_COUNTERS() are the above
.................... // constants for the 1st param and the following for
.................... // the 2nd param:
.................... ////////////////////////////////////////////////////////////////// WDT
.................... // Watch Dog Timer Functions: SETUP_WDT() or SETUP_COUNTERS() (see above)
.................... //                            RESTART_WDT()
.................... #define WDT_ON      0x100
.................... #define WDT_OFF     0
.................... ////////////////////////////////////////////////////////////////// Timer 1
.................... // Timer 1 Functions: SETUP_TIMER_1, GET_TIMER1, SET_TIMER1
.................... // Constants used for SETUP_TIMER_1() are:
.................... //      (or (via |) together constants from each group)
.................... #define T1_DISABLED         0
.................... #define T1_INTERNAL         0x85
.................... #define T1_EXTERNAL         0x87
.................... #define T1_EXTERNAL_SYNC    0x83
.................... #define T1_CLK_OUT          8
.................... #define T1_DIV_BY_1         0
.................... #define T1_DIV_BY_2         0x10
.................... #define T1_DIV_BY_4         0x20
.................... #define T1_DIV_BY_8         0x30
.................... ////////////////////////////////////////////////////////////////// Timer 2
.................... // Timer 2 Functions: SETUP_TIMER_2, GET_TIMER2, SET_TIMER2
.................... // Constants used for SETUP_TIMER_2() are:
.................... #define T2_DISABLED         0
.................... #define T2_DIV_BY_1         4
.................... #define T2_DIV_BY_4         5
.................... #define T2_DIV_BY_16        6
.................... ////////////////////////////////////////////////////////////////// Timer 3
.................... // Timer 3 Functions: SETUP_TIMER_3, GET_TIMER3, SET_TIMER3
.................... // Constants used for SETUP_TIMER_3() are:
.................... #define T3_DISABLED         0
.................... #define T3_INTERNAL         0x85
.................... #define T3_EXTERNAL         0x87
.................... #define T3_EXTERNAL_SYNC    0x83
.................... #define T3_DIV_BY_1         0
.................... #define T3_DIV_BY_2         0x10
.................... #define T3_DIV_BY_4         0x20
.................... #define T3_DIV_BY_8         0x30
.................... ////////////////////////////////////////////////////////////////// CCP
.................... // CCP Functions: SETUP_CCPx, SET_PWMx_DUTY
.................... // CCP Variables: CCP_x, CCP_x_LOW, CCP_x_HIGH
.................... // Constants used for SETUP_CCPx() are:
.................... #define CCP_OFF                         0
.................... #define CCP_CAPTURE_FE                  4
.................... #define CCP_CAPTURE_RE                  5
.................... #define CCP_CAPTURE_DIV_4               6
.................... #define CCP_CAPTURE_DIV_16              7
.................... #define CCP_COMPARE_SET_ON_MATCH        8
.................... #define CCP_COMPARE_CLR_ON_MATCH        9
.................... #define CCP_COMPARE_INT                 0xA
.................... #define CCP_COMPARE_INT_AND_TOGGLE      0x2
.................... #define CCP_COMPARE_RESET_TIMER         0xB
.................... #define CCP_PWM                         0xC
.................... #define CCP_PWM_PLUS_1                  0x1c
.................... #define CCP_PWM_PLUS_2                  0x2c
.................... #define CCP_PWM_PLUS_3                  0x3c
.................... #define CCP_USE_TIMER3                  0x100
.................... long CCP_1;
.................... #byte   CCP_1    =                      0xfbe
.................... #byte   CCP_1_LOW=                      0xfbe
.................... #byte   CCP_1_HIGH=                     0xfbf
.................... long CCP_2;
.................... #byte   CCP_2    =                      0xfbb
.................... #byte   CCP_2_LOW=                      0xfbb
.................... #byte   CCP_2_HIGH=                     0xfbc
.................... ////////////////////////////////////////////////////////////////// PSP
.................... // PSP Functions: SETUP_PSP, PSP_INPUT_FULL(), PSP_OUTPUT_FULL(),
.................... //                PSP_OVERFLOW(), INPUT_D(), OUTPUT_D()
.................... // PSP Variables: PSP_DATA
.................... // Constants used in SETUP_PSP() are:
.................... #define PSP_ENABLED                     0x10
.................... #define PSP_DISABLED                    0
.................... #byte  PSP_DATA=    0xF83
.................... ////////////////////////////////////////////////////////////////// SPI
.................... // SPI Functions: SETUP_SPI, SPI_WRITE, SPI_READ, SPI_DATA_IN
.................... // Constants used in SETUP_SSP() are:
.................... #define SPI_MASTER       0x20
.................... #define SPI_SLAVE        0x24
.................... #define SPI_L_TO_H       0
.................... #define SPI_H_TO_L       0x10
.................... #define SPI_CLK_DIV_4    0
.................... #define SPI_CLK_DIV_16   1
.................... #define SPI_CLK_DIV_64   2
.................... #define SPI_CLK_T2       3
.................... #define SPI_SS_DISABLED  1
.................... #define SPI_SAMPLE_AT_END 0x8000
.................... #define SPI_XMIT_L_TO_H  0x4000
.................... ////////////////////////////////////////////////////////////////// UART
.................... // Constants used in setup_uart() are:
.................... // FALSE - Turn UART off
.................... // TRUE  - Turn UART on
.................... #define UART_ADDRESS           2
.................... #define UART_DATA              4
.................... ////////////////////////////////////////////////////////////////// VREF
.................... // Constants used in setup_low_volt_detect() are:
.................... #define LVD_LVDIN   0x1F
.................... #define LVD_46 0x1E
.................... #define LVD_43 0x1D
.................... #define LVD_41 0x1C
.................... #define LVD_40 0x1B
.................... #define LVD_37 0x1A
.................... #define LVD_36 0x19
.................... #define LVD_34 0x18
.................... #define LVD_31 0x17
.................... #define LVD_29 0x16
.................... #define LVD_28 0x15
.................... #define LVD_26 0x14
.................... #define LVD_25 0x13
.................... #define LVD_23 0x12
.................... #define LVD_21 0x11
.................... ////////////////////////////////////////////////////////////////// INTERNAL RC
.................... // Constants used in setup_oscillator() are:
.................... #define OSC_TIMER1  1
.................... #define OSC_NORMAL  0
.................... ////////////////////////////////////////////////////////////////// ADC
.................... // ADC Functions: SETUP_ADC(), SETUP_ADC_PORTS() (aka SETUP_PORT_A),
.................... //                SET_ADC_CHANNEL(), READ_ADC()
.................... // Constants used for SETUP_ADC() are:
.................... #define ADC_OFF                 0              // ADC Off
.................... #define ADC_CLOCK_DIV_2   0x10000
.................... #define ADC_CLOCK_DIV_4    0x4000
.................... #define ADC_CLOCK_DIV_8    0x0040
.................... #define ADC_CLOCK_DIV_16   0x4040
.................... #define ADC_CLOCK_DIV_32   0x0080
.................... #define ADC_CLOCK_DIV_64   0x4080
.................... #define ADC_CLOCK_INTERNAL 0x00c0              // Internal 2-6us
.................... // Constants used in SETUP_ADC_PORTS() are:
.................... #define NO_ANALOGS                           7    // None
.................... #define ALL_ANALOG                           0    // A0 A1 A2 A3 A5 E0 E1 E2
.................... #define AN0_AN1_AN2_AN4_AN5_AN6_AN7_VSS_VREF 1    // A0 A1 A2 A5 E0 E1 E2 VRefh=A3
.................... #define AN0_AN1_AN2_AN3_AN4                  2    // A0 A1 A2 A3 A5
.................... #define AN0_AN1_AN2_AN4_VSS_VREF             3    // A0 A1 A2 A5 VRefh=A3
.................... #define AN0_AN1_AN3                          4    // A0 A1 A3
.................... #define AN0_AN1_VSS_VREF                     5    // A0 A1 VRefh=A3
.................... #define AN0_AN1_AN4_AN5_AN6_AN7_VREF_VREF 0x08    // A0 A1 A5 E0 E1 E2 VRefh=A3 VRefl=A2
.................... #define AN0_AN1_AN2_AN3_AN4_AN5           0x09    // A0 A1 A2 A3 A5 E0
.................... #define AN0_AN1_AN2_AN4_AN5_VSS_VREF      0x0A    // A0 A1 A2 A5 E0 VRefh=A3
.................... #define AN0_AN1_AN4_AN5_VREF_VREF         0x0B    // A0 A1 A5 E0 VRefh=A3 VRefl=A2
.................... #define AN0_AN1_AN4_VREF_VREF             0x0C    // A0 A1 A5 VRefh=A3 VRefl=A2
.................... #define AN0_AN1_VREF_VREF                 0x0D    // A0 A1 VRefh=A3 VRefl=A2
.................... #define AN0                               0x0E    // A0
.................... #define AN0_VREF_VREF                     0x0F    // A0 VRefh=A3 VRefl=A2
.................... #define ANALOG_RA3_REF         0x1         //!old only provided for compatibility
.................... #define A_ANALOG               0x2         //!old only provided for compatibility
.................... #define A_ANALOG_RA3_REF       0x3         //!old only provided for compatibility
.................... #define RA0_RA1_RA3_ANALOG     0x4         //!old only provided for compatibility
.................... #define RA0_RA1_ANALOG_RA3_REF 0x5         //!old only provided for compatibility
.................... #define ANALOG_RA3_RA2_REF              0x8   //!old only provided for compatibility
.................... #define ANALOG_NOT_RE1_RE2              0x9   //!old only provided for compatibility
.................... #define ANALOG_NOT_RE1_RE2_REF_RA3      0xA   //!old only provided for compatibility
.................... #define ANALOG_NOT_RE1_RE2_REF_RA3_RA2  0xB   //!old only provided for compatibility
.................... #define A_ANALOG_RA3_RA2_REF            0xC   //!old only provided for compatibility
.................... #define RA0_RA1_ANALOG_RA3_RA2_REF      0xD   //!old only provided for compatibility
.................... #define RA0_ANALOG                      0xE   //!old only provided for compatibility
.................... #define RA0_ANALOG_RA3_RA2_REF          0xF   //!old only provided for compatibility
.................... // Constants used in READ_ADC() are:
.................... #define ADC_START_AND_READ     7   // This is the default if nothing is specified
.................... #define ADC_START_ONLY         1
.................... #define ADC_READ_ONLY          6
.................... // Interrupt Functions: ENABLE_INTERRUPTS(), DISABLE_INTERRUPTS(),
.................... //                      EXT_INT_EDGE()
.................... // Constants used in EXT_INT_EDGE() are:
.................... #define L_TO_H              0x40
.................... #define H_TO_L                 0
.................... // Constants used in ENABLE/DISABLE_INTERRUPTS() are:
.................... #define GLOBAL                    0xF2C0
.................... #define INT_RTCC                  0xF220
.................... #define INT_TIMER0                0xF220
.................... #define INT_TIMER1                0x9D01
.................... #define INT_TIMER2                0x9D02
.................... #define INT_TIMER3                0xA002
.................... #define INT_EXT                   0xF210
.................... #define INT_EXT1                  0xF008
.................... #define INT_EXT2                  0xF010
.................... #define INT_RB                    0xF208
.................... #define INT_PSP                   0x9D80
.................... #define INT_AD                    0x9D40
.................... #define INT_RDA                   0x9D20
.................... #define INT_TBE                   0x9D10
.................... #define INT_SSP                   0x9D08
.................... #define INT_CCP1                  0x9D04
.................... #define INT_CCP2                  0xA001
.................... #define INT_BUSCOL                0xA008
.................... #define INT_LOWVOLT               0xA004
.................... #define INT_EEPROM                0xA010
.................... #define hi(x)  (*(&x+1))  //data held at addr of x + 1
.................... #define lo(x)  (*(&x))    //data held at addr of x
.................... #org 0x7FE1, 0x7FFF  //puts 2.00 3.01 1 (0200030101) at 0x7FF0
.................... const char revision[] = {FIRM_MAJOR,FIRM_MINOR,HARD_MAJOR,HARD_MINOR,PROD_ID};
.................... #org default
.................... //===========LOADER_SIZE============//
.................... #define LOADER_ADDR 0x20
.................... #define LOADER_SIZE 0x200
.................... #define LOADER_END  LOADER_ADDR + LOADER_SIZE
.................... #build(reset=LOADER_END+2, interrupt=LOADER_END+8)
.................... //---------------- GLOBAL VAR --------------------
.................... int8 RX_BUF[64];
.................... //===================== PrgmPIC =========================
.................... //Assumes RX_BUF[0] is defined as global. char RX_BUF[256]; or at least 64
.................... //Notice how we reprogram to 0x7D00 and this function is stored after
.................... //that at address 0x7D18.  This is as high as we could go.
.................... #org LOADER_ADDR,LOADER_END
.................... #use I2C(MASTER,SDA=PIN_C4,SCL=PIN_C3,FORCE_HW,FAST,RESTART_WDT)
0000:  BCF    FC6.7
0002:  BCF    F9E.3
0004:  MOVFF  50,FC9
0008:  MOVLW  02
000A:  BTFSC  FC6.7
000C:  BRA    0018
000E:  BTFSS  F9E.3
0010:  BRA    000E
0012:  MOVLW  00
0014:  BTFSC  FC5.6
0016:  MOVLW  01
0018:  MOVWF  01
001A:  RETLW  00
022A:  BSF    FC5.3
022C:  BTFSC  FC5.3
022E:  BRA    022C
0230:  BTFSC  00.0
0232:  BCF    FC5.5
0234:  BTFSS  00.0
0236:  BSF    FC5.5
0238:  BSF    FC5.4
023A:  BTFSC  FC5.4
023C:  BRA    023A
023E:  MOVFF  FC9,01
0242:  RETLW  00
.................... void PrgmPIC(void){
....................   int32 address;
....................   int8 data,size;
....................   #define block 64
....................   char *ptr_char;
....................   disable_interrupts(GLOBAL);
0020:  BCF    FF2.6
0022:  BCF    FF2.7
0024:  BTFSC  FF2.7
0026:  BRA    0022
....................   for(address=0;address<0x7D00;address+=block){ //read 8 bytes prgm from fram
0028:  CLRF   48
002A:  CLRF   47
002C:  CLRF   46
002E:  CLRF   45
0030:  MOVF   48,F
0032:  BTFSS  FD8.2
0034:  BRA    01CC
0036:  MOVF   47,F
0038:  BTFSS  FD8.2
003A:  BRA    01CC
003C:  MOVF   46,W
003E:  SUBLW  7C
0040:  BTFSS  FD8.0
0042:  BRA    01CC
....................     ptr_char=&RX_BUF[0];//&RX_BUF[0] is defined as global. char RX_BUF[256];
0044:  CLRF   4C
0046:  MOVLW  05
0048:  MOVWF  4B
....................     for(size=block;size;ptr_char++,size--){
004A:  MOVLW  40
004C:  MOVWF  4A
004E:  MOVF   4A,F
0050:  BTFSC  FD8.2
0052:  BRA    014C
....................       if(size==block){
0054:  MOVF   4A,W
0056:  SUBLW  40
0058:  BNZ   0106
....................         i2c_start();
005A:  BSF    FC5.0
005C:  BTFSC  FC5.0
005E:  BRA    005C
....................         i2c_write((0xA0|(int8)(address>>14))&0xFE);//&0xFE forces to write
0060:  CLRF   03
0062:  RRCF   48,W
0064:  MOVWF  02
0066:  RRCF   47,W
0068:  MOVWF  01
006A:  RRCF   46,W
006C:  MOVWF  00
006E:  RRCF   02,F
0070:  RRCF   01,F
0072:  RRCF   00,F
0074:  RRCF   02,F
0076:  RRCF   01,F
0078:  RRCF   00,F
007A:  RRCF   02,F
007C:  RRCF   01,F
007E:  RRCF   00,F
0080:  RRCF   02,F
0082:  RRCF   01,F
0084:  RRCF   00,F
0086:  RRCF   02,F
0088:  RRCF   01,F
008A:  RRCF   00,F
008C:  MOVLW  03
008E:  ANDWF  02,F
0090:  MOVF   00,W
0092:  IORLW  A0
0094:  ANDLW  FE
0096:  MOVWF  4F
0098:  MOVWF  50
009A:  RCALL  0000
....................         i2c_write(hi(address));
009C:  CLRF   03
009E:  MOVLW  46
00A0:  MOVWF  FE9
00A2:  MOVFF  03,FEA
00A6:  MOVFF  FEF,4D
00AA:  MOVFF  4D,50
00AE:  RCALL  0000
....................         i2c_write(lo(address));
00B0:  CLRF   03
00B2:  MOVLW  45
00B4:  MOVWF  FE9
00B6:  MOVFF  03,FEA
00BA:  MOVFF  FEF,4D
00BE:  MOVFF  4D,50
00C2:  RCALL  0000
00C4:  BSF    FC5.1
00C6:  BTFSC  FC5.1
00C8:  BRA    00C6
....................         i2c_write((0xA0|(int8)(address>>14))|1);//|1 forces to read
00CA:  CLRF   03
00CC:  RRCF   48,W
00CE:  MOVWF  02
00D0:  RRCF   47,W
00D2:  MOVWF  01
00D4:  RRCF   46,W
00D6:  MOVWF  00
00D8:  RRCF   02,F
00DA:  RRCF   01,F
00DC:  RRCF   00,F
00DE:  RRCF   02,F
00E0:  RRCF   01,F
00E2:  RRCF   00,F
00E4:  RRCF   02,F
00E6:  RRCF   01,F
00E8:  RRCF   00,F
00EA:  RRCF   02,F
00EC:  RRCF   01,F
00EE:  RRCF   00,F
00F0:  RRCF   02,F
00F2:  RRCF   01,F
00F4:  RRCF   00,F
00F6:  MOVLW  03
00F8:  ANDWF  02,F
00FA:  MOVF   00,W
00FC:  IORLW  A0
00FE:  IORLW  01
0100:  MOVWF  4F
0102:  MOVWF  50
0104:  RCALL  0000
....................       if(size==1)
0106:  DECFSZ 4A,W
0108:  BRA    0126
....................         *ptr_char=i2c_read(0);//No ack on last read of chip
010A:  MOVFF  4C,03
010E:  MOVFF  4B,FE9
0112:  MOVFF  4C,FEA
0116:  CLRF   00
0118:  RCALL  022A
011A:  MOVFF  01,FEF
....................         i2c_stop();
011E:  BSF    FC5.2
0120:  BTFSC  FC5.2
0122:  BRA    0120
....................       else
0124:  BRA    013C
....................         *ptr_char=i2c_read(1);//The ack will put next data on bus
0126:  MOVFF  4C,03
012A:  MOVFF  4B,FE9
012E:  MOVFF  4C,FEA
0132:  MOVLW  01
0134:  MOVWF  00
0136:  RCALL  022A
0138:  MOVFF  01,FEF
013C:  MOVFF  4C,03
0140:  MOVF   4B,W
0142:  INCF   4B,F
0144:  BTFSC  FD8.2
0146:  INCF   4C,F
0148:  DECF   4A,F
014A:  BRA    004E
....................     write_program_memory(address,&RX_BUF[0],64);//write=8,erase=64
014C:  BSF    FD0.6
014E:  BCF    FA6.6
0150:  MOVFF  47,FF8
0154:  MOVFF  46,FF7
0158:  MOVFF  45,FF6
015C:  MOVF   FF6,W
015E:  ANDLW  07
0160:  MOVWF  00
0162:  MOVLW  F8
0164:  ANDWF  FF6,F
0166:  TBLRD*-
0168:  CLRF   FEA
016A:  MOVLW  05
016C:  MOVWF  FE9
016E:  MOVLW  40
0170:  MOVWF  01
0172:  MOVWF  02
0174:  MOVLW  08
0176:  TSTFSZ 00
0178:  ADDWF  02,F
017A:  MOVF   02,W
017C:  ADDLW  07
017E:  ANDLW  F8
0180:  MOVWF  02
0182:  MOVF   FF6,W
0184:  TSTFSZ 00
0186:  BRA    0196
0188:  ADDLW  01
018A:  ANDLW  3F
018C:  BNZ   0196
018E:  BSF    FA6.4
0190:  TBLRD*+
0192:  RCALL  0244
0194:  TBLRD*-
0196:  TSTFSZ 00
0198:  BRA    01A8
019A:  MOVFF  FEE,FF5
019E:  MOVF   01,F
01A0:  BZ    01AA
01A2:  TBLWT+*
01A4:  DECF   01,F
01A6:  BRA    01AE
01A8:  DECF   00,F
01AA:  TBLRD+*
01AC:  TBLWT*
01AE:  MOVLW  07
01B0:  ANDWF  FF6,W
01B2:  XORLW  07
01B4:  BTFSC  FD8.2
01B6:  RCALL  0244
01B8:  DECFSZ 02,F
01BA:  BRA    0182
01BC:  CLRF   FF8
01BE:  MOVLW  40
01C0:  ADDWF  45,F
01C2:  MOVLW  00
01C4:  ADDWFC 46,F
01C6:  ADDWFC 47,F
01C8:  ADDWFC 48,F
01CA:  BRA    0030
....................   reset_cpu();
01CC:  RESET
01CE:  RETLW  00
.................... //---------------- MAIN --------------------
.................... void main(void){
0264:  CLRF   FF8
0266:  BCF    FD0.7
0268:  CLRF   FEA
026A:  CLRF   FE9
026C:  BSF    F94.3
026E:  BSF    F94.4
0270:  CLRF   FC8
0272:  MOVLW  28
0274:  MOVWF  FC6
0276:  BCF    FC7.7
0278:  BCF    FC7.6
027A:  BSF    FC1.0
027C:  BSF    FC1.1
027E:  BSF    FC1.2
0280:  BCF    FC1.3
....................   while(1){
....................     if(!input(PIN_A0)){
0282:  BSF    F92.0
0284:  BTFSC  F80.0
0286:  BRA    028A
....................       PrgmPIC();
0288:  RCALL  0020
028A:  BRA    0282
028C:  SLEEP
PostPosted: Tue Feb 14, 2006 2:29 am     Reply with quote
The line in bold is the relocated reset code. It just jumps to main(),
which is at address 0x0264.
0222: GOTO 0264
You won't see anything for the relocated interrupt dispatcher code
because you don't have any #INT_XXX statement(s) in your program.
Also, is it your intention that the CCS i2c library code be #org'ed
in the LOADER_ADDR segment ? If so, you need to add the "Default"
directive at the end of the #org statement. You'll also have to
increase LOADER_SIZE to 0x220, because it needs a little bit more room.
treitmey
PostPosted: Tue Feb 14, 2006 8:42 am     Reply with quote
Exactly what I was going for.
And yes, I cut my program to nothing and didn't make the connection that no IRQ means no IRQ redirector.
AND yes I do want the I2C functions.. but if they go pass the protected 512 boot area will I get in trouble?
or
I just have to keep in mind not to program that space. Right?
PostPosted: Tue Feb 14, 2006 2:16 pm     Reply with quote
Do you want the i2c library code to be entirely inside the #org'ed area ?
