treitmey
What does the moved IRQ/RESET look like in a list file? |
Posted: Mon Feb 13, 2006 5:58 pm |
I want to verify that my #build statement did what I want.
Code: | //=======================//
#define FIRM_MAJOR 2
#define FIRM_MINOR 00
#define HARD_MAJOR 3
#define HARD_MINOR 01
#define PROD_ID 1
#include <18f452.h>
#define hi(x) (*(&x+1)) //data held at addr of x + 1
#define lo(x) (*(&x)) //data held at addr of x
#org 0x7FE1, 0x7FFF //puts 2.00 3.01 1 (0200030101) at 0x7FF0
const char revision[] = {FIRM_MAJOR,FIRM_MINOR,HARD_MAJOR,HARD_MINOR,PROD_ID};
#org default
//===========LOADER_SIZE============//
#define LOADER_ADDR 0x20
#define LOADER_SIZE 0x200
#define LOADER_END LOADER_ADDR + LOADER_SIZE
#build(reset=LOADER_END+2, interrupt=LOADER_END+8)
//---------------- GLOBAL VAR --------------------
int8 RX_BUF[64];
//===================== PrgmPIC =========================
//Assumes RX_BUF[0] is defined as global. char RX_BUF[256]; or at least 64
#org LOADER_ADDR,LOADER_END
#use I2C(MASTER,SDA=PIN_C4,SCL=PIN_C3,FORCE_HW,FAST,RESTART_WDT)
void PrgmPIC(void){
int32 address;
int8 data,size;
#define block 64
char *ptr_char;
disable_interrupts(GLOBAL);
for(address=0;address<0x7D00;address+=block){ //read 8 bytes prgm from fram
ptr_char=&RX_BUF[0];//&RX_BUF[0] is defined as global. char RX_BUF[256];
for(size=block;size;ptr_char++,size--){
if(size==block){
i2c_start();
i2c_write((0xA0|(int8)(address>>14))&0xFE);//&0xFE forces to write
i2c_write(hi(address));
i2c_write(lo(address));
i2c_start();
i2c_write((0xA0|(int8)(address>>14))|1);//|1 forces to read
if(size==1)
*ptr_char=i2c_read(0);//No ack on last read of chip
i2c_stop();
*ptr_char=i2c_read(1);//The ack will put next data on bus
write_program_memory(address,&RX_BUF[0],64);//write=8,erase=64
reset_cpu();
#org default
//---------------- MAIN --------------------
void main(void){
while(1){
if(!input(PIN_A0)){
PrgmPIC();
And the listing
CCS PCH C Compiler, Version 3.242, 30995 13-Feb-06 16:55
Filename: C:\ccs\Projects\3200I\update_firmware\t_197.lst
ROM used: 588 bytes (2%)
Largest free fragment is 32082
RAM used: 69 (4%) at main() level
81 (5%) worst case
Stack: 3 worst case (2 in main + 1 for interrupts)
0222: GOTO 0264
.................... #define FIRM_MAJOR 2
.................... #define FIRM_MINOR 00
.................... #define HARD_MAJOR 3
.................... #define HARD_MINOR 01
.................... #define PROD_ID 1
.................... #include <18f452.h>
.................... //////// Standard Header file for the PIC18F452 device ////////////////
.................... #device PIC18F452
0244: MOVF FF2,W
0246: MOVWF 03
0248: BCF FF2.7
024A: BSF FA6.7
024C: BSF FA6.2
024E: MOVLB F
0250: MOVLW 55
0252: MOVWF FA7
0254: MOVLW AA
0256: MOVWF FA7
0258: BSF FA6.1
025A: NOP
025C: MOVF 03,W
025E: IORWF FF2,F
0260: MOVLB 0
0262: RETLW 00
7FE0: CLRF FF7
7FE2: ADDLW F0
7FE4: MOVWF FF6
7FE6: MOVLW 7F
7FE8: ADDWFC FF7,F
7FEA: TBLRD*+
7FEC: MOVF FF5,W
7FEE: RETURN 0
7FF0: DATA 02,00
7FF2: DATA 03,01
7FF4: DATA 01,00
7FF6: RETLW 00
.................... //#nolist
.................... #list //2/13/2006 4:38PM tjr for a full list
.................... //////// Program memory: 16384x16 Data RAM: 1536 Stack: 31
.................... //////// I/O: 34 Analog Pins: 8
.................... //////// Data EEPROM: 256
.................... //////// C Scratch area: 00 ID Location: 2000
.................... //////// Fuses: LP,XT,HS,RC,EC,EC_IO,H4,RC_IO,PROTECT,NOPROTECT,OSCSEN
.................... //////// Fuses: NOOSCSEN,NOBROWNOUT,BROWNOUT,WDT1,WDT2,WDT4,WDT8,WDT16,WDT32
.................... //////// Fuses: WDT64,WDT128,WDT,NOWDT,BORV20,BORV27,BORV42,BORV45,PUT,NOPUT
.................... //////// Fuses: CCP2C1,CCP2B3,NOSTVREN,STVREN,NODEBUG,DEBUG,NOLVP,LVP,WRT
.................... //////// Fuses: NOWRT,NOWRTD,WRTD,NOWRTB,WRTB,WRTC,NOWRTC,CPD,NOCPD,CPB
.................... //////// Fuses: NOCPB,EBTR,NOEBTR,EBTRB,NOEBTRB
.................... ////////////////////////////////////////////////////////////////// I/O
.................... // Discrete I/O Functions: SET_TRIS_x(), OUTPUT_x(), INPUT_x(),
.................... // PORT_B_PULLUPS(), INPUT(),
.................... // OUTPUT_LOW(), OUTPUT_HIGH(),
.................... // OUTPUT_FLOAT(), OUTPUT_BIT()
.................... // Constants used to identify pins in the above are:
.................... #define PIN_A0 31744
.................... #define PIN_A1 31745
.................... #define PIN_A2 31746
.................... #define PIN_A3 31747
.................... #define PIN_A4 31748
.................... #define PIN_A5 31749
.................... #define PIN_A6 31750
.................... #define PIN_B0 31752
.................... #define PIN_B1 31753
.................... #define PIN_B2 31754
.................... #define PIN_B3 31755
.................... #define PIN_B4 31756
.................... #define PIN_B5 31757
.................... #define PIN_B6 31758
.................... #define PIN_B7 31759
.................... #define PIN_C0 31760
.................... #define PIN_C1 31761
.................... #define PIN_C2 31762
.................... #define PIN_C3 31763
.................... #define PIN_C4 31764
.................... #define PIN_C5 31765
.................... #define PIN_C6 31766
.................... #define PIN_C7 31767
.................... #define PIN_D0 31768
.................... #define PIN_D1 31769
.................... #define PIN_D2 31770
.................... #define PIN_D3 31771
.................... #define PIN_D4 31772
.................... #define PIN_D5 31773
.................... #define PIN_D6 31774
.................... #define PIN_D7 31775
.................... #define PIN_E0 31776
.................... #define PIN_E1 31777
.................... #define PIN_E2 31778
.................... ////////////////////////////////////////////////////////////////// Useful defines
.................... #define FALSE 0
.................... #define TRUE 1
.................... #define BYTE int
.................... #define BOOLEAN short int
.................... #define getc getch
.................... #define fgetc getch
.................... #define getchar getch
.................... #define putc putchar
.................... #define fputc putchar
.................... #define fgets gets
.................... #define fputs puts
.................... ////////////////////////////////////////////////////////////////// Control
.................... // Control Functions: RESET_CPU(), SLEEP(), RESTART_CAUSE()
.................... // Constants returned from RESTART_CAUSE() are:
.................... #define WDT_TIMEOUT 7
.................... #define MCLR_FROM_SLEEP 11
.................... #define MCLR_FROM_RUN 15
.................... #define NORMAL_POWER_UP 12
.................... #define BROWNOUT_RESTART 14
.................... #define WDT_FROM_SLEEP 3
.................... #define RESET_INSTRUCTION 0
.................... ////////////////////////////////////////////////////////////////// Timer 0
.................... // Timer 0 (AKA RTCC)Functions: SETUP_COUNTERS() or SETUP_TIMER_0(),
.................... // SET_TIMER0() or SET_RTCC(),
.................... // GET_TIMER0() or GET_RTCC()
.................... // Constants used for SETUP_TIMER_0() are:
.................... #define RTCC_INTERNAL 0
.................... #define RTCC_EXT_L_TO_H 32
.................... #define RTCC_EXT_H_TO_L 48
.................... #define RTCC_DIV_1 8
.................... #define RTCC_DIV_2 0
.................... #define RTCC_DIV_4 1
.................... #define RTCC_DIV_8 2
.................... #define RTCC_DIV_16 3
.................... #define RTCC_DIV_32 4
.................... #define RTCC_DIV_64 5
.................... #define RTCC_DIV_128 6
.................... #define RTCC_DIV_256 7
.................... #define RTCC_OFF 0x80
.................... #define RTCC_8_BIT 0x40
.................... // Constants used for SETUP_COUNTERS() are the above
.................... // constants for the 1st param and the following for
.................... // the 2nd param:
.................... ////////////////////////////////////////////////////////////////// WDT
.................... // Watch Dog Timer Functions: SETUP_WDT() or SETUP_COUNTERS() (see above)
.................... // RESTART_WDT()
.................... #define WDT_ON 0x100
.................... #define WDT_OFF 0
.................... ////////////////////////////////////////////////////////////////// Timer 1
.................... // Timer 1 Functions: SETUP_TIMER_1, GET_TIMER1, SET_TIMER1
.................... // Constants used for SETUP_TIMER_1() are:
.................... // (or (via |) together constants from each group)
.................... #define T1_DISABLED 0
.................... #define T1_INTERNAL 0x85
.................... #define T1_EXTERNAL 0x87
.................... #define T1_EXTERNAL_SYNC 0x83
.................... #define T1_CLK_OUT 8
.................... #define T1_DIV_BY_1 0
.................... #define T1_DIV_BY_2 0x10
.................... #define T1_DIV_BY_4 0x20
.................... #define T1_DIV_BY_8 0x30
.................... ////////////////////////////////////////////////////////////////// Timer 2
.................... // Timer 2 Functions: SETUP_TIMER_2, GET_TIMER2, SET_TIMER2
.................... // Constants used for SETUP_TIMER_2() are:
.................... #define T2_DISABLED 0
.................... #define T2_DIV_BY_1 4
.................... #define T2_DIV_BY_4 5
.................... #define T2_DIV_BY_16 6
.................... ////////////////////////////////////////////////////////////////// Timer 3
.................... // Timer 3 Functions: SETUP_TIMER_3, GET_TIMER3, SET_TIMER3
.................... // Constants used for SETUP_TIMER_3() are:
.................... #define T3_DISABLED 0
.................... #define T3_INTERNAL 0x85
.................... #define T3_EXTERNAL 0x87
.................... #define T3_EXTERNAL_SYNC 0x83
.................... #define T3_DIV_BY_1 0
.................... #define T3_DIV_BY_2 0x10
.................... #define T3_DIV_BY_4 0x20
.................... #define T3_DIV_BY_8 0x30
.................... ////////////////////////////////////////////////////////////////// CCP
.................... // CCP Functions: SETUP_CCPx, SET_PWMx_DUTY
.................... // CCP Variables: CCP_x, CCP_x_LOW, CCP_x_HIGH
.................... // Constants used for SETUP_CCPx() are:
.................... #define CCP_OFF 0
.................... #define CCP_CAPTURE_FE 4
.................... #define CCP_CAPTURE_RE 5
.................... #define CCP_CAPTURE_DIV_4 6
.................... #define CCP_CAPTURE_DIV_16 7
.................... #define CCP_COMPARE_SET_ON_MATCH 8
.................... #define CCP_COMPARE_CLR_ON_MATCH 9
.................... #define CCP_COMPARE_INT 0xA
.................... #define CCP_COMPARE_INT_AND_TOGGLE 0x2
.................... #define CCP_COMPARE_RESET_TIMER 0xB
.................... #define CCP_PWM 0xC
.................... #define CCP_PWM_PLUS_1 0x1c
.................... #define CCP_PWM_PLUS_2 0x2c
.................... #define CCP_PWM_PLUS_3 0x3c
.................... #define CCP_USE_TIMER3 0x100
.................... long CCP_1;
.................... #byte CCP_1 = 0xfbe
.................... #byte CCP_1_LOW= 0xfbe
.................... #byte CCP_1_HIGH= 0xfbf
.................... long CCP_2;
.................... #byte CCP_2 = 0xfbb
.................... #byte CCP_2_LOW= 0xfbb
.................... #byte CCP_2_HIGH= 0xfbc
.................... ////////////////////////////////////////////////////////////////// PSP
.................... // PSP Functions: SETUP_PSP, PSP_INPUT_FULL(), PSP_OUTPUT_FULL(),
.................... // PSP_OVERFLOW(), INPUT_D(), OUTPUT_D()
.................... // PSP Variables: PSP_DATA
.................... // Constants used in SETUP_PSP() are:
.................... #define PSP_ENABLED 0x10
.................... #define PSP_DISABLED 0
.................... #byte PSP_DATA= 0xF83
.................... ////////////////////////////////////////////////////////////////// SPI
.................... // SPI Functions: SETUP_SPI, SPI_WRITE, SPI_READ, SPI_DATA_IN
.................... // Constants used in SETUP_SSP() are:
.................... #define SPI_MASTER 0x20
.................... #define SPI_SLAVE 0x24
.................... #define SPI_L_TO_H 0
.................... #define SPI_H_TO_L 0x10
.................... #define SPI_CLK_DIV_4 0
.................... #define SPI_CLK_DIV_16 1
.................... #define SPI_CLK_DIV_64 2
.................... #define SPI_CLK_T2 3
.................... #define SPI_SS_DISABLED 1
.................... #define SPI_SAMPLE_AT_END 0x8000
.................... #define SPI_XMIT_L_TO_H 0x4000
.................... ////////////////////////////////////////////////////////////////// UART
.................... // Constants used in setup_uart() are:
.................... // FALSE - Turn UART off
.................... // TRUE - Turn UART on
.................... #define UART_ADDRESS 2
.................... #define UART_DATA 4
.................... ////////////////////////////////////////////////////////////////// VREF
.................... // Constants used in setup_low_volt_detect() are:
.................... #define LVD_LVDIN 0x1F
.................... #define LVD_46 0x1E
.................... #define LVD_43 0x1D
.................... #define LVD_41 0x1C
.................... #define LVD_40 0x1B
.................... #define LVD_37 0x1A
.................... #define LVD_36 0x19
.................... #define LVD_34 0x18
.................... #define LVD_31 0x17
.................... #define LVD_29 0x16
.................... #define LVD_28 0x15
.................... #define LVD_26 0x14
.................... #define LVD_25 0x13
.................... #define LVD_23 0x12
.................... #define LVD_21 0x11
.................... ////////////////////////////////////////////////////////////////// INTERNAL RC
.................... // Constants used in setup_oscillator() are:
.................... #define OSC_TIMER1 1
.................... #define OSC_NORMAL 0
.................... ////////////////////////////////////////////////////////////////// ADC
.................... // ADC Functions: SETUP_ADC(), SETUP_ADC_PORTS() (aka SETUP_PORT_A),
.................... // SET_ADC_CHANNEL(), READ_ADC()
.................... // Constants used for SETUP_ADC() are:
.................... #define ADC_OFF 0 // ADC Off
.................... #define ADC_CLOCK_DIV_2 0x10000
.................... #define ADC_CLOCK_DIV_4 0x4000
.................... #define ADC_CLOCK_DIV_8 0x0040
.................... #define ADC_CLOCK_DIV_16 0x4040
.................... #define ADC_CLOCK_DIV_32 0x0080
.................... #define ADC_CLOCK_DIV_64 0x4080
.................... #define ADC_CLOCK_INTERNAL 0x00c0 // Internal 2-6us
.................... // Constants used in SETUP_ADC_PORTS() are:
.................... #define NO_ANALOGS 7 // None
.................... #define ALL_ANALOG 0 // A0 A1 A2 A3 A5 E0 E1 E2
.................... #define AN0_AN1_AN2_AN4_AN5_AN6_AN7_VSS_VREF 1 // A0 A1 A2 A5 E0 E1 E2 VRefh=A3
.................... #define AN0_AN1_AN2_AN3_AN4 2 // A0 A1 A2 A3 A5
.................... #define AN0_AN1_AN2_AN4_VSS_VREF 3 // A0 A1 A2 A5 VRefh=A3
.................... #define AN0_AN1_AN3 4 // A0 A1 A3
.................... #define AN0_AN1_VSS_VREF 5 // A0 A1 VRefh=A3
.................... #define AN0_AN1_AN4_AN5_AN6_AN7_VREF_VREF 0x08 // A0 A1 A5 E0 E1 E2 VRefh=A3 VRefl=A2
.................... #define AN0_AN1_AN2_AN3_AN4_AN5 0x09 // A0 A1 A2 A3 A5 E0
.................... #define AN0_AN1_AN2_AN4_AN5_VSS_VREF 0x0A // A0 A1 A2 A5 E0 VRefh=A3
.................... #define AN0_AN1_AN4_AN5_VREF_VREF 0x0B // A0 A1 A5 E0 VRefh=A3 VRefl=A2
.................... #define AN0_AN1_AN4_VREF_VREF 0x0C // A0 A1 A5 VRefh=A3 VRefl=A2
.................... #define AN0_AN1_VREF_VREF 0x0D // A0 A1 VRefh=A3 VRefl=A2
.................... #define AN0 0x0E // A0
.................... #define AN0_VREF_VREF 0x0F // A0 VRefh=A3 VRefl=A2
.................... #define ANALOG_RA3_REF 0x1 //!old only provided for compatibility
.................... #define A_ANALOG 0x2 //!old only provided for compatibility
.................... #define A_ANALOG_RA3_REF 0x3 //!old only provided for compatibility
.................... #define RA0_RA1_RA3_ANALOG 0x4 //!old only provided for compatibility
.................... #define RA0_RA1_ANALOG_RA3_REF 0x5 //!old only provided for compatibility
.................... #define ANALOG_RA3_RA2_REF 0x8 //!old only provided for compatibility
.................... #define ANALOG_NOT_RE1_RE2 0x9 //!old only provided for compatibility
.................... #define ANALOG_NOT_RE1_RE2_REF_RA3 0xA //!old only provided for compatibility
.................... #define ANALOG_NOT_RE1_RE2_REF_RA3_RA2 0xB //!old only provided for compatibility
.................... #define A_ANALOG_RA3_RA2_REF 0xC //!old only provided for compatibility
.................... #define RA0_RA1_ANALOG_RA3_RA2_REF 0xD //!old only provided for compatibility
.................... #define RA0_ANALOG 0xE //!old only provided for compatibility
.................... #define RA0_ANALOG_RA3_RA2_REF 0xF //!old only provided for compatibility
.................... // Constants used in READ_ADC() are:
.................... #define ADC_START_AND_READ 7 // This is the default if nothing is specified
.................... #define ADC_START_ONLY 1
.................... #define ADC_READ_ONLY 6
.................... // Interrupt Functions: ENABLE_INTERRUPTS(), DISABLE_INTERRUPTS(),
.................... // EXT_INT_EDGE()
.................... // Constants used in EXT_INT_EDGE() are:
.................... #define L_TO_H 0x40
.................... #define H_TO_L 0
.................... // Constants used in ENABLE/DISABLE_INTERRUPTS() are:
.................... #define GLOBAL 0xF2C0
.................... #define INT_RTCC 0xF220
.................... #define INT_TIMER0 0xF220
.................... #define INT_TIMER1 0x9D01
.................... #define INT_TIMER2 0x9D02
.................... #define INT_TIMER3 0xA002
.................... #define INT_EXT 0xF210
.................... #define INT_EXT1 0xF008
.................... #define INT_EXT2 0xF010
.................... #define INT_RB 0xF208
.................... #define INT_PSP 0x9D80
.................... #define INT_AD 0x9D40
.................... #define INT_RDA 0x9D20
.................... #define INT_TBE 0x9D10
.................... #define INT_SSP 0x9D08
.................... #define INT_CCP1 0x9D04
.................... #define INT_CCP2 0xA001
.................... #define INT_BUSCOL 0xA008
.................... #define INT_LOWVOLT 0xA004
.................... #define INT_EEPROM 0xA010
.................... #define hi(x) (*(&x+1)) //data held at addr of x + 1
.................... #define lo(x) (*(&x)) //data held at addr of x
.................... #org 0x7FE1, 0x7FFF //puts 2.00 3.01 1 (0200030101) at 0x7FF0
.................... const char revision[] = {FIRM_MAJOR,FIRM_MINOR,HARD_MAJOR,HARD_MINOR,PROD_ID};
.................... #org default
.................... //===========LOADER_SIZE============//
.................... #define LOADER_ADDR 0x20
.................... #define LOADER_SIZE 0x200
.................... #define LOADER_END LOADER_ADDR + LOADER_SIZE
.................... #build(reset=LOADER_END+2, interrupt=LOADER_END+8)
.................... //---------------- GLOBAL VAR --------------------
.................... int8 RX_BUF[64];
.................... //===================== PrgmPIC =========================
.................... //Assumes RX_BUF[0] is defined as global. char RX_BUF[256]; or at least 64
.................... //Notice how we reprogram to 0x7D00 and this function is stored after
.................... //that at address 0x7D18. This is as high as we could go.
.................... #org LOADER_ADDR,LOADER_END
.................... #use I2C(MASTER,SDA=PIN_C4,SCL=PIN_C3,FORCE_HW,FAST,RESTART_WDT)
0000: BCF FC6.7
0002: BCF F9E.3
0004: MOVFF 50,FC9
0008: MOVLW 02
000A: BTFSC FC6.7
000C: BRA 0018
000E: BTFSS F9E.3
0010: BRA 000E
0012: MOVLW 00
0014: BTFSC FC5.6
0016: MOVLW 01
0018: MOVWF 01
001A: RETLW 00
022A: BSF FC5.3
022C: BTFSC FC5.3
022E: BRA 022C
0230: BTFSC 00.0
0232: BCF FC5.5
0234: BTFSS 00.0
0236: BSF FC5.5
0238: BSF FC5.4
023A: BTFSC FC5.4
023C: BRA 023A
023E: MOVFF FC9,01
0242: RETLW 00
.................... void PrgmPIC(void){
.................... int32 address;
.................... int8 data,size;
.................... #define block 64
.................... char *ptr_char;
.................... disable_interrupts(GLOBAL);
0020: BCF FF2.6
0022: BCF FF2.7
0024: BTFSC FF2.7
0026: BRA 0022
.................... for(address=0;address<0x7D00;address+=block){ //read 8 bytes prgm from fram
0028: CLRF 48
002A: CLRF 47
002C: CLRF 46
002E: CLRF 45
0030: MOVF 48,F
0032: BTFSS FD8.2
0034: BRA 01CC
0036: MOVF 47,F
0038: BTFSS FD8.2
003A: BRA 01CC
003C: MOVF 46,W
003E: SUBLW 7C
0040: BTFSS FD8.0
0042: BRA 01CC
.................... ptr_char=&RX_BUF[0];//&RX_BUF[0] is defined as global. char RX_BUF[256];
0044: CLRF 4C
0046: MOVLW 05
0048: MOVWF 4B
.................... for(size=block;size;ptr_char++,size--){
004A: MOVLW 40
004C: MOVWF 4A
004E: MOVF 4A,F
0050: BTFSC FD8.2
0052: BRA 014C
.................... if(size==block){
0054: MOVF 4A,W
0056: SUBLW 40
0058: BNZ 0106
.................... i2c_start();
005A: BSF FC5.0
005C: BTFSC FC5.0
005E: BRA 005C
.................... i2c_write((0xA0|(int8)(address>>14))&0xFE);//&0xFE forces to write
0060: CLRF 03
0062: RRCF 48,W
0064: MOVWF 02
0066: RRCF 47,W
0068: MOVWF 01
006A: RRCF 46,W
006C: MOVWF 00
006E: RRCF 02,F
0070: RRCF 01,F
0072: RRCF 00,F
0074: RRCF 02,F
0076: RRCF 01,F
0078: RRCF 00,F
007A: RRCF 02,F
007C: RRCF 01,F
007E: RRCF 00,F
0080: RRCF 02,F
0082: RRCF 01,F
0084: RRCF 00,F
0086: RRCF 02,F
0088: RRCF 01,F
008A: RRCF 00,F
008C: MOVLW 03
008E: ANDWF 02,F
0090: MOVF 00,W
0092: IORLW A0
0094: ANDLW FE
0096: MOVWF 4F
0098: MOVWF 50
009A: RCALL 0000
.................... i2c_write(hi(address));
009C: CLRF 03
009E: MOVLW 46
00A0: MOVWF FE9
00A2: MOVFF 03,FEA
00A6: MOVFF FEF,4D
00AA: MOVFF 4D,50
00AE: RCALL 0000
.................... i2c_write(lo(address));
00B0: CLRF 03
00B2: MOVLW 45
00B4: MOVWF FE9
00B6: MOVFF 03,FEA
00BA: MOVFF FEF,4D
00BE: MOVFF 4D,50
00C2: RCALL 0000
00C4: BSF FC5.1
00C6: BTFSC FC5.1
00C8: BRA 00C6
.................... i2c_write((0xA0|(int8)(address>>14))|1);//|1 forces to read
00CA: CLRF 03
00CC: RRCF 48,W
00CE: MOVWF 02
00D0: RRCF 47,W
00D2: MOVWF 01
00D4: RRCF 46,W
00D6: MOVWF 00
00D8: RRCF 02,F
00DA: RRCF 01,F
00DC: RRCF 00,F
00DE: RRCF 02,F
00E0: RRCF 01,F
00E2: RRCF 00,F
00E4: RRCF 02,F
00E6: RRCF 01,F
00E8: RRCF 00,F
00EA: RRCF 02,F
00EC: RRCF 01,F
00EE: RRCF 00,F
00F0: RRCF 02,F
00F2: RRCF 01,F
00F4: RRCF 00,F
00F6: MOVLW 03
00F8: ANDWF 02,F
00FA: MOVF 00,W
00FC: IORLW A0
00FE: IORLW 01
0100: MOVWF 4F
0102: MOVWF 50
0104: RCALL 0000
.................... if(size==1)
0106: DECFSZ 4A,W
0108: BRA 0126
.................... *ptr_char=i2c_read(0);//No ack on last read of chip
010A: MOVFF 4C,03
010E: MOVFF 4B,FE9
0112: MOVFF 4C,FEA
0116: CLRF 00
0118: RCALL 022A
011A: MOVFF 01,FEF
.................... i2c_stop();
011E: BSF FC5.2
0120: BTFSC FC5.2
0122: BRA 0120
.................... else
0124: BRA 013C
.................... *ptr_char=i2c_read(1);//The ack will put next data on bus
0126: MOVFF 4C,03
012A: MOVFF 4B,FE9
012E: MOVFF 4C,FEA
0132: MOVLW 01
0134: MOVWF 00
0136: RCALL 022A
0138: MOVFF 01,FEF
013C: MOVFF 4C,03
0140: MOVF 4B,W
0142: INCF 4B,F
0144: BTFSC FD8.2
0146: INCF 4C,F
0148: DECF 4A,F
014A: BRA 004E
.................... write_program_memory(address,&RX_BUF[0],64);//write=8,erase=64
014C: BSF FD0.6
014E: BCF FA6.6
0150: MOVFF 47,FF8
0154: MOVFF 46,FF7
0158: MOVFF 45,FF6
015C: MOVF FF6,W
015E: ANDLW 07
0160: MOVWF 00
0162: MOVLW F8
0164: ANDWF FF6,F
0166: TBLRD*-
0168: CLRF FEA
016A: MOVLW 05
016C: MOVWF FE9
016E: MOVLW 40
0170: MOVWF 01
0172: MOVWF 02
0174: MOVLW 08
0176: TSTFSZ 00
0178: ADDWF 02,F
017A: MOVF 02,W
017C: ADDLW 07
017E: ANDLW F8
0180: MOVWF 02
0182: MOVF FF6,W
0184: TSTFSZ 00
0186: BRA 0196
0188: ADDLW 01
018A: ANDLW 3F
018C: BNZ 0196
018E: BSF FA6.4
0190: TBLRD*+
0192: RCALL 0244
0194: TBLRD*-
0196: TSTFSZ 00
0198: BRA 01A8
019A: MOVFF FEE,FF5
019E: MOVF 01,F
01A0: BZ 01AA
01A2: TBLWT+*
01A4: DECF 01,F
01A6: BRA 01AE
01A8: DECF 00,F
01AA: TBLRD+*
01AC: TBLWT*
01AE: MOVLW 07
01B0: ANDWF FF6,W
01B2: XORLW 07
01B4: BTFSC FD8.2
01B6: RCALL 0244
01B8: DECFSZ 02,F
01BA: BRA 0182
01BC: CLRF FF8
01BE: MOVLW 40
01C0: ADDWF 45,F
01C2: MOVLW 00
01C4: ADDWFC 46,F
01C6: ADDWFC 47,F
01C8: ADDWFC 48,F
01CA: BRA 0030
.................... reset_cpu();
01CC: RESET
01CE: RETLW 00
.................... //---------------- MAIN --------------------
.................... void main(void){
0264: CLRF FF8
0266: BCF FD0.7
0268: CLRF FEA
026A: CLRF FE9
026C: BSF F94.3
026E: BSF F94.4
0270: CLRF FC8
0272: MOVLW 28
0274: MOVWF FC6
0276: BCF FC7.7
0278: BCF FC7.6
027A: BSF FC1.0
027C: BSF FC1.1
027E: BSF FC1.2
0280: BCF FC1.3
.................... while(1){
.................... if(!input(PIN_A0)){
0282: BSF F92.0
0284: BTFSC F80.0
0286: BRA 028A
.................... PrgmPIC();
0288: RCALL 0020
028A: BRA 0282
028C: SLEEP
Posted: Tue Feb 14, 2006 2:29 am |
Quote: | What does the moved IRQ/RESET look like in a list file?
I want to verify that my #build statement did what I want. |
The line in bold is the relocated reset code. It just jumps to main(),
which is at address 0x0264.
Quote: |
0222: GOTO 0264
.................... #define PROD_ID 1 |
You won't see anything for the relocated interrupt dispatcher code
because you don't have any #INT_XXX statement(s) in your program.
Also, is it your intention that the CCS i2c library code be #org'ed
in the LOADER_ADDR segment ? If so, you need to add the "Default"
directive at the end of the #org statement. You'll also have to
increase LOADER_SIZE to 0x220, because it needs a little bit more room. |
treitmey
Posted: Tue Feb 14, 2006 8:42 am |
Exactly what I was going for.
And yes, I cut my program to nothing and didn't make the connection that no IRQ means no IRQ redirector.
AND yes I do want the I2C functions.. but if they go pass the protected 512 boot area will I get in trouble?
or
I just have to keep in mind not to program that space. Right? |
Posted: Tue Feb 14, 2006 2:16 pm |
Do you want the i2c library code to be entirely inside the #org'ed area ? |
