The above document explains 4x4 keypad multiplexing very thoroughly. You can also read the well-commented assembly language program that goes with it.
I'm sure you can use the app note and the tech tip documents to write C code for it.
Storic
Joined: 03 Dec 2005 Posts: 182 Location: Australia SA
Posted: Mon Feb 13, 2006 12:06 am
After some consideration. I was tring to code it simular to the KBD.C driver. It is a different animal and need to be coded differently. I will research more.
Andrew _________________ What has been learnt if you make the same mistake?
