4X4 Keypad 4x io
Storic
4X4 Keypad 4x io
PostPosted: Sun Feb 12, 2006 11:29 pm     Reply with quote
I found this in the tech tip from microchip has any one done any coding for something like this, Tech Tip #12 microchip
2 x analog and 2 x Digital IO = 4 x4 matrix keypad
http://ww1.microchip.com/downloads/en/devicedoc/41261a.pdf
I would like some guidance to this
Andrew
What has been learnt if you make the same mistake? Wink
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Sun Feb 12, 2006 11:57 pm     Reply with quote
What guidance do you want? The tech tip #12 has nine well-documented step-by-step instructions on how to implement it.
MikeValencia
PostPosted: Mon Feb 13, 2006 12:03 am     Reply with quote
http://ww1.microchip.com/downloads/en/appnotes/00529e.pdf
The above document explains 4x4 keypad multiplexing very thoroughly. You can also read the well-commented assembly language program that goes with it.
I'm sure you can use the app note and the tech tip documents to write C code for it.
Storic
PostPosted: Mon Feb 13, 2006 12:06 am     Reply with quote
After some consideration. I was tring to code it simular to the KBD.C driver. It is a different animal and need to be coded differently. I will research more.
Andrew
