elburro1887
Problem with HEX file |
Posted: Tue Feb 14, 2006 3:50 am |
I have a problem when generating a HEX file. when i compile a program, the PIC C Compiler appends the line ";PIC16F876" to the HEX text.
However, the PIC burner i'm using doesnt like that line, and i have to delete it everytime i want to burn the PIC.
Is there some kind of setting in the compiler to prevent this from happening? |
Posted: Tue Feb 14, 2006 5:40 am |
I'm afraid not.
The line is legitimate Intel Hex (the format originally defined that any line _not_ beginning with a ':', should be ignored - unfortunately, many of the abridged 'defintions' on the web, miss this bit, and quite a few programmers based on these will then complain). There was a long thread about this quite a while ago, and I'd suspect the easiest solution might be a little program to strip any line that doesn't start with a :....
