Guys i'm working on a thermistor.I'm using lcd to display the temperatures and would like to add a (oC).Has nayone ver done?Any experience with this!
newguy
Posted: Fri Feb 10, 2006 12:22 am
The degree symbol itself (o) is either 0xdf or 0xfd. Just send that number to the lcd with
lcd_putc(0xdf);
If you require a oC as one character, you'll have to create it yourself in the lcd's character RAM. Search this board for code and examples.
Guest Guest
Great..
Posted: Fri Feb 10, 2006 12:34 am
Any specific link on please.Thanks
Guest Guest
Printing zero
Posted: Fri Feb 10, 2006 12:50 am
The one you have given prints 0
lcd_putc(0xdf);
this print zero not o.
I tried both but they give the same result...
