LCD and degree symbol!!
PostPosted: Fri Feb 10, 2006 12:04 am     Reply with quote
Guys i'm working on a thermistor.I'm using lcd to display the temperatures and would like to add a (oC).Has nayone ver done?Any experience with this!
Thanks Sad
newguy
PostPosted: Fri Feb 10, 2006 12:22 am     Reply with quote
The degree symbol itself (o) is either 0xdf or 0xfd. Just send that number to the lcd with
lcd_putc(0xdf);
If you require a oC as one character, you'll have to create it yourself in the lcd's character RAM. Search this board for code and examples.
Great..
PostPosted: Fri Feb 10, 2006 12:34 am     Reply with quote
Any specific link on please.Thanks
Printing zero
PostPosted: Fri Feb 10, 2006 12:50 am     Reply with quote
The one you have given prints 0
lcd_putc(0xdf);
this print zero not o.
I tried both but they give the same result...
Crying or Very sad
newguy
PostPosted: Fri Feb 10, 2006 12:53 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=25743&highlight=lcdsendbyte+custom
That help!
PostPosted: Fri Feb 10, 2006 2:35 am     Reply with quote
Problem solved thank you for your help...
