does anyone here know which pic16f877a package that can operate with 3.3v suply and i/o level at 3.3volts? i have a problem interfacing pic with rf txrx chip that i've bought since the chip operates at 3.3v and can only receive signal at that level... suggestion anyone?
thankx a zillion~!
kender
Posted: Thu Dec 22, 2005 3:00 am
The LF series of PICs operate at low voltages. There are 18LF452 and 18LF4520, which should be pin-for-pin compatible with 16F887.
You can add a simple voltage divider or a 5V-tolerant buffer, which will convert 5V ot 3.3V.
Posted: Thu Dec 22, 2005 11:49 am
Go to http://www.digikey.com/ and search for: 16LF877A
They stock four package types for the LF version.
The LF version has a maximum speed of 10 MHz at 3.3 volts.
