Clock Switching
darren_gould
Clock Switching
PostPosted: Fri Dec 09, 2005 6:15 am     Reply with quote
Hallo,
I have an application that needs to switch from the internal to external clock (ECIO).
I have to start out on the internal clock (since my fuses are set to ECIO I imagine this is in clock fail mode) and program some external hardware. Once the external hardware is programmed, a 13.56 MHz clock appears (which is attached to my OSC1 pin).
I'm using a PIC16F767 and CCS Compiler 3.200.
Problem is, when I call setup_oscillator with OSC_NORMAL it then switches over to the 32 KHz internal clock - even though the 13.56 MHz clock is correctly on the OSC1 pin.
Any thoughts as to what is causing the problem.
#include <16f767.h>
#device ICD=TRUE
#ROM 0x2007 = {0x2763}
#ROM 0x2008 = {0x3FFF}
main()
SETUP_ADC_PORTS(NO_ANALOGS);
SETUP_ADC(ADC_OFF);                  // disable A2D
SETUP_COMPARATOR(NC_NC_NC_NC);      // default settings
SETUP_CCP1(CCP_OFF);
SETUP_CCP2(CCP_OFF);
InitHW();                    // Hardware initialisation - subroutine not shown
delay_ms(2000);
setup_oscillator(OSC_NORMAL);
PostPosted: Fri Dec 09, 2005 9:26 am     Reply with quote
Read the processor's .h file.
Note the constants for 'setup_oscillator'. Pay special attention to 'OSC_TIMER1'.
