I have an application that needs to switch from the internal to external clock (ECIO).
I have to start out on the internal clock (since my fuses are set to ECIO I imagine this is in clock fail mode) and program some external hardware. Once the external hardware is programmed, a 13.56 MHz clock appears (which is attached to my OSC1 pin).
I'm using a PIC16F767 and CCS Compiler 3.200.
Problem is, when I call setup_oscillator with OSC_NORMAL it then switches over to the 32 KHz internal clock - even though the 13.56 MHz clock is correctly on the OSC1 pin.
