SPI PROBLEM IN 18F4550
PIC_INDIAN
PostPosted: Sat Nov 26, 2005 11:07 pm     Reply with quote
i have problem in setup_spi while using 18F4550,
if i setup the spi the spi clock didn't genererated, but while i am using the same code for 18F452 it is working fine, plse tell me what may be the problem
Note: eventhough i configured the PORTB as digital IO on reset.
PostPosted: Sun Nov 27, 2005 2:30 pm     Reply with quote
I have problem in setup_spi while using 18F4550,
1. Post a small test program that shows the problem.
See my post in the following link. It shows a simple test
program for spi write. Make a similar program for your
PIC, test it, and then post it.
http://www.ccsinfo.com/forum/viewtopic.php?t=24861
2. Also post your compiler version. This will be a number such
as 3.191, or 3.239, etc. You can find it at the top of the .LST
file for you project. It will be in your project folder.
