What is the meaning of development board ??
arunb
PostPosted: Tue Nov 01, 2005 9:05 am     Reply with quote
What is the meaning of development board. Is it possible to program the PIC directly from the PC or does the PIC have to be removed and put in a seperate programmer ??
thanks
arunb
dyeatman
PostPosted: Tue Nov 01, 2005 9:18 am     Reply with quote
Many of the "development boards" have the in-circuit serial programming (ICSP) connector on the board and you can program the PIC right on the board. A few even have the entire programmer circuit on the development board.
With the ICSP connector you still have to have an external programmer/interface between the PC and the board like the ICD2 or the ICDU-40 or ICS-40. If you want to buld your own ICSP interface there are a number of them out there to choose from.
treitmey
PostPosted: Tue Nov 01, 2005 9:20 am     Reply with quote
I think most people on this forum use a programmer or a boot loader.
So
PC connects to a programmer. ((programmer is ICD2 or CCS_ICD-U40))
programmer connects to target board through the ICD port.
Or
You can re-program a board directly from a PC IF [[IF]] that board has allready been programmed with a boot loader.
To get the ' ' ' FIRST' ' ' boot loader on the PICyou still need a programmer.
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Tue Nov 01, 2005 9:47 am     Reply with quote
I figured a "development board" is synonymous with a "demo board". They have enough sample circuits on there to fulfill a "proof of concept".
Before the days of ICSP in PICs, your development/demo board obviously didn't have rj11 jacks to program the chip in-circuit. But it was still a development board.
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue Nov 01, 2005 1:06 pm     Reply with quote
The meaning of a developemnt board is to charge you a few hundred bucks.
arunb
RE:
PostPosted: Thu Nov 03, 2005 1:37 am     Reply with quote
Is it OK to have a development board and not have ICD or ICSP ,and no on board programming ???
thanks
arunb
kender
Re: RE:
PostPosted: Thu Nov 03, 2005 1:42 am     Reply with quote
No! I haven't seen a PIC development board, which wouldn't require some kind of programmer.
SherpaDoug
PostPosted: Thu Nov 03, 2005 7:39 am     Reply with quote
Before flash chips and ICSP it was common for development boards to just have the uC in a socket so you could pop it out to erase and program elsewhere.
asmallri
Re: RE:
PostPosted: Thu Nov 03, 2005 8:33 am     Reply with quote
Actually there are several develoment boards that have embedded bootloaders and do not reuire ICD or ICSP
http://www.ez-devices.com/asp/listing.asp?cat=1
http://www.picaxe.com
Regards, Andrew
MikeValencia
PostPosted: Thu Nov 03, 2005 10:17 am     Reply with quote
Back in the pre-ICSP days of OTP and UV erasable PICs (e.g. PIC16C72), they also sold boards to develop code on. What were those boards called?
dyeatman
PostPosted: Thu Nov 03, 2005 10:41 am     Reply with quote
This company sells development boards with the PIC programmer built into the board.
http://www.mikroelektronika.co.yu/english/
