akokyaw
How to convert the code in PBP "shiftout" into C? |
Posted: Wed Oct 12, 2005 9:58 am |
Hi everybody,
I would like to know how to convert the code in PBP as "shiftout SI,SCK,1,[%1100\4]" into C. I have read some topic about converting "shiftout" command as follow:
Code: | void ShiftOut (int8 data)
output_low(OUT_CLOCK);
if((data&0x80)==0)
output_low(OUT_DO);
output_high(OUT_DO);
data <<= 1;
output_high(OUT_CLOCK);
I want to add the variable like "OUT_CLOCK", "OUT_DO" as follow:
Code: | void ShiftOut(int16 OUT_CLOCK, int16 OUT_DO, int8 data) |
Is it possible to do this code? Any idea? or suggestion?
Thanks,
ako |
Mark
akokyaw
Mark
Posted: Wed Oct 12, 2005 8:53 pm |
The pin numbers are CCS specific but do have some meaning. Basically the port address multiplied by 8 then the bit number added to it. If you read PCM's response in the link I posted, he shows you how to do what you want with port pins. |
