How to convert the code in PBP "shiftout" into C?
akokyaw
PostPosted: Wed Oct 12, 2005 9:58 am     Reply with quote
Hi everybody,
I would like to know how to convert the code in PBP as "shiftout SI,SCK,1,[%1100\4]" into C. I have read some topic about converting "shiftout" command as follow:
void ShiftOut (int8 data)
     output_low(OUT_CLOCK);
     if((data&0x80)==0)
       output_low(OUT_DO);
       output_high(OUT_DO);
     data <<= 1;
     output_high(OUT_CLOCK);
I want to add the variable like "OUT_CLOCK", "OUT_DO" as follow:
 void ShiftOut(int16 OUT_CLOCK, int16 OUT_DO, int8 data)
Is it possible to do this code? Any idea? or suggestion? Question
Thanks,
ako
Mark
PostPosted: Wed Oct 12, 2005 11:12 am     Reply with quote
output_high and output_low take constants as a parameter. Short answer to you question, NO you can't use a parameter as a constant. You could write you own function that accepts a variable though. This has been discussed here before.
http://www.ccsinfo.com/forum/viewtopic.php?t=24315&highlight=outputhigh+variable+parameter
akokyaw
port variable
PostPosted: Wed Oct 12, 2005 6:40 pm     Reply with quote
Thank for your response, Mark. I agree with you. But the following topic has been shown about port variable. I am not sure this method is indirect method or may be CCS style.
http://www.ccsinfo.com/forum/viewtopic.php?t=23837&highlight=button
Thanks,
ako
Mark
PostPosted: Wed Oct 12, 2005 8:53 pm     Reply with quote
The pin numbers are CCS specific but do have some meaning. Basically the port address multiplied by 8 then the bit number added to it. If you read PCM's response in the link I posted, he shows you how to do what you want with port pins.
