from Code of DS1307 I have problem ...
1. I used 18F452 with DS1307
2. I have R 10K Pull Up at SLK,SDA with +5V
3. I have coin Battery 3.0 V
4. Crystal is OK.
when I connect coin battery to pin 3 DS1307.Result is 25/45/-91 45:85:85
when I remove coin battery from pin 3 DS1307.Result is 4/19/02 12:11:03
