DS1307 Problem
Porn
DS1307 Problem
PostPosted: Sun Sep 18, 2005 6:39 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=23255&highlight=ds1307
from Code of DS1307 I have problem ...
1. I used 18F452 with DS1307
2. I have R 10K Pull Up at SLK,SDA with +5V
3. I have coin Battery 3.0 V
4. Crystal is OK.
when I connect coin battery to pin 3 DS1307.Result is 25/45/-91 45:85:85
when I remove coin battery from pin 3 DS1307.Result is 4/19/02 12:11:03
Why?
please help me...
PostPosted: Sun Sep 18, 2005 1:29 pm     Reply with quote
Read this thread for more things to check:
http://www.ccsinfo.com/forum/viewtopic.php?t=19926&start=0
Also, check your battery with a voltmeter. Is it really 3.0v or
is it only 1.5v ?
Porn
PostPosted: Sun Sep 18, 2005 7:14 pm     Reply with quote
Thank you for answer.
from... PCM Programmer
is it only 1.5v ?
coin battery voltage = 3.0 V (in circuit and out circuit)
I think Hardware is OK.becuase I try with another circiut the same result.
but I think Software is OK.
what wrong?
can tell me why?
PostPosted: Sun Sep 18, 2005 9:00 pm     Reply with quote
Check all the connections, and all the component values, and the program.
Also try a different DS1307 chip.
Park
PostPosted: Mon Sep 19, 2005 11:46 am     Reply with quote
check out this example
may be help your solution.
