andrew1956
18F2550 Serial Port Please a simple example |
Posted: Mon Jul 25, 2005 9:45 am |
Hi
Is possible a simple example about how programming Master Synchronus Serial Port included in this Pic ?
How receive and send data, change baud and parameters data
Very thanks
Adrew |
Posted: Mon Jul 25, 2005 1:03 pm |
The MSSP is used for SPI or i2c. Which one do you want to use ? |
andrew1956
Posted: Mon Jul 25, 2005 4:49 pm |
Hi PCM
Very thanks for you response
I need obtain a Serial Port Virtual
Think method is SPI Mode
Ok?
Andrew |
Posted: Mon Jul 25, 2005 5:23 pm |
Quote: | I need obtain a Serial Port Virtual |
I don't know anything about it. It appears to be a program that
runs on a PC that "looks like" two RS232 COM ports.
On a PIC, the USART is used for RS232. The MSSP is not used.
That's all the help I can give you. |
andrew1956
Posted: Tue Jul 26, 2005 2:44 am |
Hi again and thanks PCM
Well
How programming USART in Pic 18F2550 ?
Is possible a example
Thanks again |
rwyoung
Posted: Tue Jul 26, 2005 7:18 am |
Look at the manual for "#use RS232", putc(), getc() etc.
Also browse the example files that came with the compiler, several good examples of how to do interrupt and non-interrupt driven serial communications between a PIC's UART and a PC's UART. _________________ Rob Young
