18F2550 Serial Port Please a simple example
andrew1956
PostPosted: Mon Jul 25, 2005 9:45 am     Reply with quote
Hi
Is possible a simple example about how programming Master Synchronus Serial Port included in this Pic ?
How receive and send data, change baud and parameters data
Very thanks
Adrew
PostPosted: Mon Jul 25, 2005 1:03 pm     Reply with quote
The MSSP is used for SPI or i2c. Which one do you want to use ?
andrew1956
PostPosted: Mon Jul 25, 2005 4:49 pm     Reply with quote
Hi PCM
Very thanks for you response
I need obtain a Serial Port Virtual
Think method is SPI Mode
Ok?
Andrew
PostPosted: Mon Jul 25, 2005 5:23 pm     Reply with quote
I don't know anything about it. It appears to be a program that
runs on a PC that "looks like" two RS232 COM ports.
On a PIC, the USART is used for RS232. The MSSP is not used.
That's all the help I can give you.
andrew1956
PostPosted: Tue Jul 26, 2005 2:44 am     Reply with quote
Hi again and thanks PCM
Well
How programming USART in Pic 18F2550 ?
Is possible a example
Thanks again
rwyoung
PostPosted: Tue Jul 26, 2005 7:18 am     Reply with quote
Look at the manual for "#use RS232", putc(), getc() etc.
Also browse the example files that came with the compiler, several good examples of how to do interrupt and non-interrupt driven serial communications between a PIC's UART and a PC's UART.
Rob Young
