C-question
valemike
C-question
PostPosted: Thu Jul 14, 2005 11:54 am     Reply with quote
I've got a general C question. Say I call the function my_fxn(), and i'm stuck in the while-loop. The normal way to get out of the while loop is if tmr0_value gets to >= 2000. However, if 'distance' ever goes more than 100, i want to break out of the while loop prematurely.
Is it correct that i use 'break;'? (The only time i've ever used 'break' was after each case in a a switch-case statement.) Or should I set a flag, and test it in the while loop?
I know this is a naive question, but i admit i don't know all my C. Embarassed
void my_fxn(void)
   while (tmr0_value < 2000)
       if (distance > 100)
   ... next instruction after while loop.
Mark
PostPosted: Thu Jul 14, 2005 12:33 pm     Reply with quote
The proper way in my book
Humberto
PostPosted: Fri Jul 15, 2005 9:25 am     Reply with quote
Hi Mike,
int16 tmr0_value;
int8  distance;
void my_fxn(void)
  do
     }while ((tmr0_value < 2000) && (distance <= 100));
Best wishes,
Humberto
kender
PostPosted: Fri Jul 15, 2005 10:00 am     Reply with quote
… and if you want to break out of a bunch of nested loop, the following trick can be useful
while (a < b)
   while (c > d)
      if (e == f)
         goto afterloop;
afterloop:
// more code …
