I have built a couple of projects already using the CAN on the PIC18F2580 and it works great. I have been contemplating using a PIC18F6680 chip in another project, and I noticed it has two CANTX pins. What is the deal with this? It wasn't obvious from looking at the datasheet why there is a CANTX1 and a CANTX2, and not just a CANTX. There is only one CANRX pin, so it doesn't make any sense to me.
Thanks. This was very helpful. The datasheet is totally vague on it. It literally has one line that says CANTX2 is a "Complimentary transmit output or CAN bus bit time clock" which doesn't help much when trying to understand what you would actually use it for. I have yet to see a tranceiver that needs a complimentary input, so it seemed strange.
