arunb
Is the RTL8019 in the driver folder an IC or a card |
Posted: Tue Jul 05, 2005 9:26 am |
Is the RTL8019 mentioned in the RTL8019.c file (in drivers folder of CCS C 0compiler; PCM type) an IC or a card.
thanks
arun |
Mark
Posted: Tue Jul 05, 2005 9:34 am |
IC |
arunb
RE: |
Posted: Fri Jul 08, 2005 5:18 am |
thanks for the reply.
arunb |
asmallri
Re: Is the RTL8019 in the driver folder an IC or a card |
Posted: Fri Jul 08, 2005 8:49 am |
arunb wrote: | Hi,
thanks
arun |
Both - if you look at the minimal configuration of a card (such as the sample schematics) with this chip you will see that it is the same as talking to the chip. I developed my first project with this chip by using a card and then striping off all the components that were not needed. There was no code change between the implementations. HOWEVER be aware that certain features of this chip require an EEPROM (configuring LED behaviour, full duplex operation etc..) If you do not plan to use an EEPROM (I don't) and you do not plan to emulate the EEPROM (I don't do this either) then you have to live with these limitations. _________________ Regards, Andrew
