Is the RTL8019 in the driver folder an IC or a card
arunb
PostPosted: Tue Jul 05, 2005 9:26 am     Reply with quote
Is the RTL8019 mentioned in the RTL8019.c file (in drivers folder of CCS C 0compiler; PCM type) an IC or a card.
thanks
arun
Mark
PostPosted: Tue Jul 05, 2005 9:34 am     Reply with quote
IC
arunb
RE:
PostPosted: Fri Jul 08, 2005 5:18 am     Reply with quote
thanks for the reply.
arunb
asmallri
Re: Is the RTL8019 in the driver folder an IC or a card
PostPosted: Fri Jul 08, 2005 8:49 am     Reply with quote
arunb wrote:
thanks
arun
Both - if you look at the minimal configuration of a card (such as the sample schematics) with this chip you will see that it is the same as talking to the chip. I developed my first project with this chip by using a card and then striping off all the components that were not needed. There was no code change between the implementations. HOWEVER be aware that certain features of this chip require an EEPROM (configuring LED behaviour, full duplex operation etc..) If you do not plan to use an EEPROM (I don't) and you do not plan to emulate the EEPROM (I don't do this either) then you have to live with these limitations.
Regards, Andrew
